- Joined
- Apr 18, 2006
- Threads
- 14
- Messages
- 169
i did and yes it works!!!!!!!
Downer said:What kind of switch is this? And what does this switch look like....from the back? Is it something that must be ordered from Toyota, or will any switch fit? You know....maybe one of those old school toggle switches could be cool....if it would fit/work.
The 2 wd ones, and the auto ones were available without the rear locker. If you got the 4x4 6 speed, it was standard.utah tojo said:I thought that a locker was standard equipment on everything but the 2-wheel drive.
Guess I had a little tunnel vision since the standard was all I ever wanted. Thanx for info.Runner Ryan said:The 2 wd ones, and the auto ones were available without the rear locker. If you got the 4x4 6 speed, it was standard.
anyone know if this works with the 2 wheel auto?
The 2 wheel comes with rear limited slip diff which gives you alot of extra traction in the slick stuff. Some times even more traction than a 4wheel with no added goodies like atrac and lockers.anyone know if this works with the 2 wheel auto?
The blank-faceplate plug in the A-TRAC position (top row - 3rd from left) had the wrong connector attached (and even more confusing, it also had a pink wire and DARK PURPLE...almost black wire as well). Since it was in the correct position, I tried shorting those wires...and it didn't work. Reading the post
above about the color codes, I found that the connector I needed in the next position to the right. After shorting the two wires (black and pink), then shifting into 4-LOW, the light came on. This looks like 2 successful tests.
I'll try putting 2 car ramps under opposite-diagonal wheels in the morning and see if i can get 4-Low to slip, then see if the A-TRAC mod makes a difference.
Pics of the mod----------
Remove panel and pop out the blank plugs to find the female connector with 4 wires.
With engine running (to simulate driving) short the pink and black wires (position 3 and 4)
Shift txfer case into 4-Low and see A-TRAC light activate.
Yes It does work, I got mine from trd source.com Put it in today. Even a cave man can do it![]()
Thanx for the info Powderpig. They should call it a-trac lite.Hello Utah Tojo:
The 2 wheel drive model does not come with the traditional type of limited slip, but uses a two wheel type of a-trac called auto limited slip. This is done with the abs system and like a-trac modulates the rear brakes to give power to the wheel that has traction. Later robbie
