AC trouble shoot
Rio Rancho, NM
I have a new compressor, condensor, drier and o ri ngs. I have a friend that helped with his guages for high and low with adding 134a. We rented a vacuum and sucked it down first.
blows moderately cold but not impressed.
I just went for a little drive to see if it got cooler but didn't really.
Is it a matter of getting it going highway speeds or time or something or do I need to just take it to a shop. Is there any ideas on what I may look at.
Belt is also new and tight. Thanks
Cooling system is new as well as engine rebuild. Haven't seen Temps on koso over 214 and that's pushing it in mountains at 9000 feet.
Highway speeds are best for maximum cool, but you did not say your method of charging. Did you weigh it in? Does the sight glass show any bubbles? What were the readings on your gauges? Your evaporator may be dirty, also. Your high side line should be very hot to the touch whereas your low side should feel nice and cool, with sweating being ideal.
Read this recent thread: AC effectivness at idle
Sight glass by the battery was showing fluid. Cant say there were any bubbles. As far as weighing in no, put in almost 3, 12 ounce bottles.
Evaporater is the only thing I didn't mess with so I guess that's likely. Is that something you can clean or what? Are they prone to failure?
High side was hot and had to let cool before we pulled the charging line off.
Heading into the mountains of sw Colorado tomorrow so I hope to get on the highway and feel a difference. Once I'm there I likely won't need the AC it's just getting there.
Fan clutch is likely stock. It was one thing I didn't improve with the cooling system. Rad, water pump, hoses are new.
Ok it may be overcharged I didn't know how to read the guages and was working on other things. But he said the third bottle went way faster then the others for some reason and likely got a little too much.
Can I release some from the valve?
Ok and closed all the way is....? I had my 6 year old move it back and forth with just the key on and the cable seems to be moving fine. I will play with it and see what's what.
