AC restriction help - no cool
piermont, NY
Had an empty system on a 93 fzj80- replaced compressor and drier- took it for vac/charge- had like 50 on low side- 130 on High side- no temp drop at vents idle / on road- cooling condensor w/ water....mechanic said there was a restriction - how do i find this ? evap or tx valve?? disconnect all lines and blow out???
thx in advance
I think if had you had a blockage you would see very high discharge press and very low (neg) suction press. With those pressures I'd guess either low charge or partially stuck/ blocked TXV. However, I have seen people install new compressors and leave the shipping caps on...
good used compressor on truck - bubbles in sight glass, heater valve working -ac clutch remaining engaged with switch
blend door/ or recirc flap prob?? it is 93 does not have auto a/c cntrl pnl function but does it have amp box??
If the compressor is engaged, idle the engine about 1200 rpm or so and feel the larger (suction) hose where it comes out of the firewall-it should be cold. The small hard line coming out of the firewall should be hot. If the temps are correct on those lines, then we know the A/C part of the system is working, and the problem is more likely in the dash. Check the heater valve to make sure it's closing all the way-mine and many others on here needed to have the cable adjusted to close it completely. If the line temps are off, it could be a bad expansion or even a weak compressor.
lines are same temp at junction block maybe slightly cooler than ambient temp-- but both generally same - no water/condensation drip- heater valve closed
Clean the in cabin condenser coil black thingy, its behind the dash. My Acura had a perfectly charged system and no cold air, turns out that box was filled with leaves and dirt inside the coild. Spent 2 hours cleaning it and im ice cold now.
What is the ambient temp? If it is only 40F to 50F ambient, you likely won't see big vent temp drops, especially I think if you are really under charged. I would say, based on my previous experience (now more than a decade ago) most mobile AC systems need to be operated at an ambient of at least 80F, to allow for proper diagnostics. At 51 psi the ref (assuming your using R134a) saturation temp is 55F, which means the air temp will be warmer that that. If evap airflow is good, but your evap air inlet temp is low, it means your evap heat load is also low. Your TXV only allows enough refrigerant into the evap such that all the liquid refrigerant that goes in is completely evaporated, which the TXV ensures is "superheated" before leaving the evaporator. A TXV's only purpose is to maintain this refrigerant "superheat" under all operating conditions. One other remote possibility is the belt may be slipping on the comp clutch. Diagnosing AC systems is difficult at best. I wish I could be of more help.
79-80 degrees - in TX - not in NY sorry
black condensor StevesNJ - u mean evap box behind glove???
Yeh thats it! Is there condensation dripping from the drain onto the ground? A little or a lot if any
Yes - condenser in front of rad and evap in dash. Do you know how much ref was added? If the ambient is 80F, then you should be seeing air vent temps at least in the 50s, assuming everything is working properly. As mentioned, could be clogged evap, NS used compressor, NS TXV, or low ref charge...
Just the answer i was looking for ! - I already changed to another compressor i had - same symptoms.. with bubbles in new drier i am thinking not condenser but TXV or Evap
I'm still going with expansion block. The evap has no moving parts, so assuming there is airflow across it and it's not plugged or leaking, that points to the expansion block. We see 50x more bad expansions than evap cores.
I did a writeup in the FAQ section on how to remove the expansion valve. It's rather easy.
thx in advance
Reviving old thread, I know, but I have this exact same issue.
Question for OP: was your issue the expansion valve? I've replaced compressor and drier and the shop I took it too said it would pull vacuum but won't charge (says blockage).
Planning on replacing expansion valve and trying again.
Thanks in advance.
Somebody's getting AC...... :)
Hopefully! :worms:
I'd rather be spending the money somewhere else on it, but we're headed to the lake for a week on the 29th, and the wifey says we HAVE to have AC in order to take the cruiser (and she wants to take the cruiser to the lake). Never look a gift horse in the mouth!
Thanks in advance.
Holy cow, this is going back a ways...let me think, I replaced the expansion valve and that might've been the cause of A/C performance loss. After replacing the valve and doing the things mentioned on my FAQ thread, things went back to normal. HTH.
Thanks!
I tore into the dash (thanks for the writeup!) and pulled the expansion valve and it was clogged up with brown crystals (I'm guessing crystallized moisture from inside the lines). My system has been down for a few years now, since I bought it from the PO, and I guess he didn't bother with investigating it.
So I went ahead and disconnected all of the lines at every junction, and flushed the system out as well with air and liquid ac flush (disconnected and sealed the drier first). I'm taking it back in this week to have a vacuum pulled and charge it up, so I'll report back to complete my part of the thread with the solution (hopefully).
In case you haven't done so, r/r the drier also, unless it's brand spanking new.
Also, rig up a pressure test gauge and see if your system holds pressure overnight. I think I posted a diy deal that I made up for this purpose. My reasoning for doing this is that the system is under 400 psi (or some such) positive pressure during operation so it stands to reason to do a 24 hour pressure leak test with either compressed air or nitrogen. Compressed air has moisture but your A/C shop will pull a vac on the system so all moisture will boil out.
If this test passes, then I'd do the same thing by putting the system under vacuum for 24 hours. Since your system has been down a while, I think it'll be worth the PITA on your part to make sure that things are tight. Otherwise, your freon will ooze out over time and you'll be annoyed. If you can't pull a vac, no worries since you passed the positive pressure test. The shop will pull a vac and make sure the system is tight.
Good luck.
