AC help
Virginia city NV.
ac compressor light comes on, on the dash. but mag clutch does not engage. if I jump 12v to mag clutch it will come on. the fan works so it is not the main relay.
on a side I don't think the heater is working either to actually blow hot air. but the blower works.
any help will help. thanks
so when I jump out the compressor clutch to get it to run no cold air comes out of the vents. but it will not run when it is hooked up to the factory harness even though the light on the dash is on. it seems likr e I lost a relay or some thing. thanks
Sounds like it's just low on a charge and the low pressure switch has tripped not allowing the compressor to turn on to save it from burning up. I'd take it to a shop and have them do a vacuum check on the system then recharge it if the system holds vacuum.
bought a can 134a kit plugged wire back in found hole in condenser big. so the system is smart and will not work if it has low pressure. I hope this helps the next guy. thank you all for the help.
I just had my condenser out to replace the expansion valve. I bought it from Rock Auto and the gasket set. I'm glad i got the gasket set, because the O ring that came with the expansion valve was wrong!
I recently replaced my entire AC system with parts from Rockauto. They offer the same exact Denso condensor for a very nice price. Takes maybe an hour to replace. This is also a good time to replace your receiver/dryer. Don't forget the pag46 oil. The FSM breaks down how much oil to put back in for each component replaced. Most oil is held in the compressor and receiver/dryer.
Did you get the lines from them as well?
I was able to use all of my existing lines. Which lines o you need?
