AC compressor not engaging
Eastern WA
I've run into an issue with the AC in my 94. Toward the end of summer the AC button at the control panel would not always engage the compressor to kick on (I.e., so audible click sound). The light above it still functions, just doesn't engage the AC.
Finally in September, I just won't kick on at all. Secondary to this the light will not come on above the air recirculation switch on the control panel. Not sure if it's related but figured I'd include it just in case.
I have read on this topic in the forum too, but still just need some guidance for this situation.
Today, I got some time to begin troubleshooting the issue.
Things I've checked:
- fuses at the engine bay and driver side dash. All fuses are intact.
- I pulled the AC amplifier and checked the circuit board (below). All solder looks good to me and I don't see anything wrong with caps or resisters.
Next I was planning to check the thermister plug at the top of the evaporator casing and use a jumper on it. I haven't tested the magnetic clutch relay either. I feel like this could be a likely culprit in this circumstance?
I think I can use a jumper on that in the engine bay to test.
How does one unplug this two wire plug? It's in such an awkward position behind the glovebox.
Any expertise on where to go from here would be greatly appreciated!
A/C is for the rich, drive faster and roll them windows down 🤣. Replace the relay cause it’s likely 30 years old, if that don’t work slap 12v to the clutch see if it actually engages then start working backwards toward the interior. More than one way to skin a polecat but what is the golden bullet? Try a little EWAG ( educated wild ass guess ) throw s*** see what sticks. You could pull the switch and jump it with a wire. It’s not a wildly complicated system but it can leave you scratching your head at times.
