Speaking of life and being busy, sorry I didn't follow up. A quick test to perform before you go any further is to carefully depress the schrader valve on the high side and then on the low side. If you get a solid amount of pressure then you're good; otherwise if its a poof of air and done, you will need to vacuum the system down to inspect for leaks. If you get no air or a tiny burst and its done, then you will need to replace the accumulator/drier. I am doing the same thing to my cruiser right now, so I feel your pain. It is better to vacuum the system down attached to a manifold and use the gauges to check for a leak, because you can also connect a can tap to the vacuum line to charge the system. Either way, you shouldn't need to jump the compressor to get refrigerant in the system. If the can is properly attached it should provide enough pressure to override the switch and cycle refrigerant into the system.
