ABS beeping when turning from a stop
Broomfield, CO
Hey guys...I'm having a weird issue where I hear a beeping sound (ABS? VSC?) when I'm turning right from a stop, almost like a wheel is slipping, but it happens on dry pavement. The day before, the VSC lights came on, and I was able to use my OBDLink MX+ to clear the codes and the lights have not come back on since. All of this happened after I came back from the mountains and sprayed the truck off at the carwash. Wondering if I somehow caused an issue with a sensor or something? Any input would be awesome. Thank you!
The VSC detect excessive wheel speed difference and trigger it. What is the code? You might have bad wheel bearing when it suddenly start doing it.
Zero point calibration issue could do this too if the wheel alignment changed and steering wheel zero point are not the same as yaw rate zero point.
