I have your same exact set up for 20 + years. FWIW setting all 6 is tricky. The mid mounts on the bell housing will work loose periodically and if the rear bushings are not right or fail it can cause the ears on the bell house to break, not the end of the world. Set the motor, bolt everything up out back use washers/spacers to get the right height on the propeller mount for your shifter and e-barke clearance on skid plate, then set the bell house mounts with appropriate washers/spacers. You dont want the bell house mounts to high thats why set the rear first. use studs at rear of tcase with loc-tite. Look at the tcase side of the AA prop mount where the rear cone is. There is a weep hole on the OEM cone cover that is not mimicked on the AA mount. That causes oil build up in the cone and subsequent leaking. Take a dremmel and re create that oil passage you see on the OEM cone cover. When you get it all up in there leave the prop mount wings unbolted, slide onto studs with a good, even coat of grey gasket maker/silicone on a clean/dry tcase, dont use so much it blocks the oil passage you created, let it set up, mount prop mount to tcase, tighten, then see where the wings line up, raise or lower tcase to clear shifter and skid, high as you can, the driver side nut or bolt head will be stuffed up against body support, its tight but doable, set bushings with spacers so tcase is at the desired height. FWIW you will want to trim the pass side frame tab for the propeller mount off right at the edge of big hole, this will let you install and remove tcase much easier, ask me how I know. It is important to mount to tcase first then wings and the weep hole is important IMO. After all that you move onto bell house mounts, I bolt the tabs to the bell house then stack a bushing, if the stock bushing is too tall cut to fit, if to short add washers. Let all the weight rest on the rear propeller mounts when setting the bell house mounts.
