- Joined
- Feb 13, 2007
- Threads
- 37
- Messages
- 172
I have had consistent overheating of my trani in my 90 HZJ73 on longer trips and especially those long hill climbs and loooong steady grades. Burnt out one trani already and now the replacement (used) is doing the same thing. Had my rad inspected and tested and they can't find anything wrong. ATF filter cleaned many times, ATF fluid checked hot and cold adn has plenty, no transfer oil going to trani, good flow from pump, system has been flushed, clutch fan cheked and workking great, any ideas what the ailment could be? I am running 5700 lbs with all my gear and just me and up to 6500lbs maxed with a passenger and gear/food etc. for long camping trips. Could it be a weight thing?
Added a turbo (T3/4 hybrid) and larger exhaust (2.5") recently to help get up those long climbs. Running 5-7 psi mostly with possibility to 12-14 for the hill climbs. EGTs between 700-800F mostly and up to 1000F on hill climbs. NO black smoke at all. Could it be running too lean?
Also, engine is overheating occasionally, suspect a common problem with rad/tranni cooler even though can't find anything wrong?
I read all postings on this forum re A440 tranis and only common answer was to replace rad. I am having my rad rebuilt from single to triple core lines (whatever they are called), supposed to be best for cooling out there and removing old tranni cooler replacing with aux tranni cooler, hope this solves problems.
Any help is most appreciated!
