I got a 91 FJ80 today. It will go in 1st gear, but wont shift to 2nd and above or go in reverse. The PO dropped the pan recently and said there was no metal shavings, and the filter was clean. Any ideas on troubleshooting?
any update on this situation. Having the exact same issue as of yesterday/I got a 91 FJ80 today. It will go in 1st gear, but wont shift to 2nd and above or go in reverse. The PO dropped the pan recently and said there was no metal shavings, and the filter was clean. Any ideas on troubleshooting?
There are 2 different transmissions being discussed in this thread.
The A440F sits behind the 3FE engine in a 1991 and 1992 FJ80. It is completely hydraulic and has NOTHING to do with vacuum lines whatsoever, so what was said in post #7 should be ignored.
The A442F sits behind the 1FZ-FE in a 1993-1994 FZJ80 and is electronically controlled with solenoids that are run by the ECU.
forum.ih8mud.com
