I’ve done my best to search abs read through all the trans threads I could find. Good/bad. Good is this is a damn good transmission. bad is I can’t find someone with similar issues.
here is goes. I have a 97 cruiser with 212k miles. When vehicle starts up and takes its first 15 miles it shifts very harsh and jumps up and down in shifting erratic. No noises. It also is sluggish off the line for that first take off.
fluid is full abs clean and I have done a few drain and replaces. It isn’t an issue where it is just cold as I can start the rig and leave it running for 20 min and still the same issue.
No lights on the dash
reverse is good
After that first 15 miles is in it runs great from that point on. Even if sitting for a few hrs and back to cold temps.
As I’m new to this trans I’m wondering if anyone has had issues with drainback. I’m thinking that as the truck sits for a longer period the converter is draining back which could cause the issues.
reminds me of the old Chrysler trans that had a drain back issue like this... or I could just be grasping for straws here.
Any thoughts?
reverse is good
Any thoughts?
