Build A Troopy Finds Its Owner
Member Build Threads
I've found since i started driving my troopie that i must watch the pyrometer nearly constantly, and that the temperature gets close to the limit very easily. Recently i figured there's got to be something that can be done about that, so i consulted with my trusted mechanic. This mechanic is well familiar with Crushers' work; he told me that what Crushers does when he installs an aftermarket turbo is that he turns up the fuel and that's it. You get good power, but it's really not worth it at highway speeds. There was in my mechanic's shop, maybe two years ago, a 77 (or a 76, i never get those right) with a 1PZ that Crushers had turbo'd sometime in the past, with a warped and/or cracked head: excess heat. Hmmm.
So with the fuel turned down about 10-15%, i haven't noticed a difference in the acceleration, but i have noticed a significant difference in the pyro gauge readings; as a direct result, on the highway i cruise at a higher speed now, with the pyro up to 150 degrees fahrenheit cooler, at a steady 100km/h. The car's not made for top speed, but all the same it should be able to hold 130km/h without any issues. Now it can; not that i want to do that with it, but i had to try: it only got close to max temp on a slight uphill, at 130km/h.
When the car was being built, i told Crushers i wanted a 3" exhaust, and he strongly advised a 2-1/2", telling me 3" was not necessary. Now my mechanic tells me there are a few other things that can be done to cool the exhaust temperatures, one of them being a 3" exhaust, as it would reduce pressure, therefore reducing temperature, etc.
I'll say it again: do not get Crushers to do your electrical or mechanical work. You'll be saving yourselves untold headaches and frustration. And significant piles of frogpelts.
As some here already know, 1978HJ45 recently sold his pick-up. Where i am is about halfway home from Georgia for Coldtaco, so he stayed over for a night. I had to take pictures (i threw two more in Coldtaco's trip thread). Fantastic to have more than one 70 around, so i rather look forward to a time when i am able to attend a Cruiser fest.
Thanks for coming by, Coldtaco.
Hi Nick, What temperatures were you getting and what are they now? I also need a tune to get my temps down.
Damienperu, at a steady 100 km/h, without wind or trailer, the pyro sits at about 700 fahrenheit now, sometimes as low as 550. Previously it wouldn't take much to get to the limit of 1200, and at a steady 100 km/h it would sit 100 too 200 degrees higher before the fuel adjustment. All these numbers are relative as the pyro needle moves about nearly non-stop. The sensor for the pyro is situated post-turbo.
Forealboreal, i've no idea what boost i'm running; this seems really silly of me to say, but i don't know any better so far: the boost gauge needle is never still, so i don't know how to answer your question.
There are a hell of a lot of mods done to this car; and there's a lot to be said for keeping a vehicle stock, i must say. A few of my issues would not exist if my car was all factory.
Increase the spring tension in your boost comp....
What boost are you running?
Forealboreal,
I've given some thought to your question. I've towed a fair bit recently, but my memory kicked in, a bit anyway. Without a trailer, and when running at a steady 100 km/h, the boost gauge on my car indicates about 4 psi. This is on flat road; so, of course, as soon as one gets on an uphill, the boost increases. But, if nothing else, this provides some indication. No i don't know what is normal; this is an aftermarket turbo installation, after all.
My first answer was based on my assuming you were looking for a setting for the turbo; i'd say my lack of knowledge of things mechanical is being highlighted here. In any case, i've never seen the boost gauge show more than 10 psi, even when hammering the snot out of the car.
I'll keep a eye on the boost gauge more in the future in an attempt to provide some more meaningful reply.
Forealboreal,
Sounds pretty normal, your wastegate is limiting to 10 psi max, you won't see it go any higher than what you already did see when hammering the snot out of it. The gauge is really only for troubleshooting, if you were to see 12 or more that will indicate a problem with your wastegate not actuating @ 10 as it should. Likewise if you see in the future that its not getting to 6 or 7 when accelerating relatively heavily, then you know your loosing pressure somewhere in the system. Not much else to think about really in terms of keeping an eye on it... just keep your eyes on the EGT!
My suggestion is to spray your underbody with a semi curing wax. Proform makes some stuff. I have done a whole bunch of that, I also us honey good and spray a few cans in my chassis and spots yearly just because.
Hello ForealBoreal,
Are you referring to the rust coming through the powder-coating?
In a bit of non-news, thought i'd throw in another picture.
Got around to replacing the rear fuel reservoir's filler neck (figured i'd rotate the tires while i was at it). It's fantastic that there's no leaking at the fuel cap now, i checked by topping the tank to the brim, drove on the rough for an hour or two, and at the angle on the second picture is confirmation of no leaking. Minor stuff, but it's a relief.
A lot of faith in an itty-bitty jack. :)
Actually, 1978HJ45, i went out of my way to find a bottle jack that was not manufactured in China; this exercise can be challenging. Until my thick skull remembered to type in the right words online, and bingo. It is made by US Jack (no, i would never have thought of that name), and it is a five ton example. So, it isn't quite itty-bitty, although it does look minor with the rest of the car around it, huh. Even for an arroguant Troopie owner, to put it in words you might understand.
Sorry, couldn't resist!
AndrewHadji, it is coming together, and thanks for the encouragement, but it is taking forever. I should be working in two months or so, so when those paycheques start moving, the Troopie will get de-crushered at a quicker rate.
:lol:
I simply mentioned it so Woody wouldn't have to change your 'MUD handle to "@squished"
I think the point is Jack Stands, regardless of the jacks origin or rating. My old man lost fingers changing brakes on a range rover when the OEM jack decided to fail.
Perhaps he'll believe another Troopy guy. :)
Thanks for the laugh, 1978HJ45. Point taken in regards to the jack stands, whether from a Troopy owner or not.
