A/C works but weakens above 90F. Tested, and looking for next steps
Super77
Seattle
99 LC, 2UZ-FE, dual A/C (front + rear).
Symptom: A/C cools normally almost all the time. Above roughly 90F ambient it starts losing ground to solar gain and can't quite keep up. Not a "no cooling" situation, just a noticeable falloff once it gets hot. Running the rear becomes mandatory and I can usually get the cabin to 70F if maxed out.
I tested with manifold gauges per the FSM (AC-3 through AC-9) procedure. Wondering if anyone's seen this pattern before or can tell me what I'm missing.
Test 1 - Static pressure, engine off
  • Ambient: 88F
  • Both gauges: 101 psi
FSM's static spec (AC-9) is 57-85 psi, but that spec doesn't call out an assumed ambient. R134a saturation pressure at 88F ambient runs close to 101 psi on its own from basic P/T chart physics, so this looked normal to me, just a hot-day reading. No leak indication.
Test 2 - Running pressure, FSM AC-4 conditions
  • Engine 2,000 rpm, fan HI, RECIRC, temp dial max cool, rear A/C on, ran 5 min idle then 5 min at 2,000 rpm before reading
  • Low side: 35 psi (FSM spec 21-36 psi - in range, upper end)
  • High side: 251 psi (FSM spec 200-213 psi - about 38 psi over spec)
Test 3 - Center vent temp
  • ~50-53F at the vent, ambient reading 85-88F on my thermocouple at the exterior rear view mirror
  • ~35-38F drop, which is on the low end of "healthy" by shop rule of thumb, not a hard FSM spec
Test 4 - Sight glass test, FSM AC-3 conditions
  • 1,500 rpm, fan HI, doors open, rear A/C on, ran 5 min
  • Shut off, at the sight glass within ~3 sec
  • Saw about 18 sec of small bubbling (not frothy, more like light carbonation), then went clear and stayed clear
FSM says: stays clear immediately = overcharge, foams then clears = correct amount. So I'm ruling out overcharge based on the bubbles I saw.
Where that leaves me per the FSM's own troubleshooting table (AC-5 to AC-8): low side normal/slightly high, high side well over spec, sight glass showing correct-charge behavior. That combination points at "insufficient cooling of condenser" - condenser airflow restriction or a weak fan clutch, not a charge problem.
What I've checked/ruled out so far:
  • Not low charge (static pressure looks right for ambient, low side is in spec, sight glass doesn't show the leak/bubbling-insufficient pattern)
  • Not overcharge (sight glass shutoff behavior matches "correct" per FSM, not "stays clear")
What I haven't done yet:
  • Haven't inspected the fin face for packed debris. However, when I replaced the radiator a year ago, I pressure washed and blew clean that whole area - it was a little dirty. So my memory says it's clean.
  • Haven't done a by-hand fan clutch check (cold vs hot resistance). FSM doesn't actually have a diagnostic spec for the fluid coupling, just R&R procedure and torque spec, so I don't have a factory pass/fail test for it
  • Haven't retested with rear A/C off to see how much that's adding to the load
Questions for the 'Mud-mind
  1. Anyone dealt with this exact pattern (fine until high ambient, high side over spec, charge/sight glass checking out fine) and had it turn out to be condenser fins vs fan clutch vs something else entirely?
  2. Any tricks for inspecting the condenser without a full front-end teardown?
  3. Since the FSM doesn't give a real diagnostic test for the fluid coupling, anyone have a reliable field test beyond "spin it by hand cold and hot"? Also curious if these are known to fail around 100k-200k miles or if mine (25 years old, original-looking Denso unit) is just an obvious swap-it-and-see candidate at this point.
  • Ambient: 88F
So does your '99 have a condenser fan? My 07 didn't have one and I added one with noticeable results but I think I saw that pre 06 models had one.
Anyway, if you have one , is it working?
It does indeed, but no mention of it in the 99 FSM. Interesting.
Behavior: after about 10min of the AC at full and engine at idle, the fan cycles on for about 20 seconds, off for 6, on for 20, etc. The cycles appear timed to the compressor clutch click.
It spins quite lazily, but it does seem to activate with some kind of predictable behavior.
@RapidRob's great q led me down this path:
At idle, max A/C, ~80F ambient, the compressor clutch cycles on a consistent 20 sec on / 6 sec off cadence. The condenser fan mostly runs in sync with the clutch (comes on when clutch engages, off when it disengages), but sometimes it does not come on at all, and it does not even activate until 10 min into idling. Vent temp drops to 44F during the "on/clutched" period, then climbs back to 50-52F during the 6 sec "off/un-clutched" period, repeating. When the condenser fan spins, it's quite slow, about half the speed of the radiator fan at idle, maybe 400 rpm or less?
Questions:
1. is this expected fan behavior?
2. is this cycling itself just normal evaporator freeze-protection behavior (system pulling down to a cutoff temp and self-protecting), or could the short on-time be a sign the system isn't cooling efficiently enough per cycle, e.g., tied to the condenser airflow issue I've been chasing?
Now I'm wondering if the cycle timing itself is a symptom or just normal operation I'm noticing because I'm paying closer attention than usual.
Anyone know what a healthy 100-series/LX470 clutch duty cycle and condenser fan cycle look like under these same conditions (idle, max A/C stationary)? Would be useful to compare against a known-good truck. FSM is no help on this.
From the symptoms you shared, it appears:
• compressor is working as designed.
• auxiliary fan may be questionable?
• condenser is working as designed.
My question is for the evaporator -whats the current condition and if there is some sort of service history?
Original, no service history on it.
What’s the condition of the evaporator fins, are they clean and free from any obstruction?
What’s the best way to access the evaporators? I’m using the plural because there’s also one for the rear AC, right?
my guess is the fan clutch isnt as strong as it once was, or your condenser and/or evaporator is dirty
Test procedure? FSM does not give one. It’s apparently a viscous coupling, so the “spin it and feel” method won’t work.
Yes our 100 series have two evaporators, onw behind glove compartment and the other at the back by the tailgate passenger side. For the front AC it’s the front evaporator, check out this link and my post (#12). The evaporator is a critical part of the AC system to function consistently.
I've been curios about a similar issue all summer.
My 99 AC has "warm spells" in 90 degree + ambient temps with rear AC on, while at highway speeds, especially while climbing grades or pulling the little off road trailer.
Engine temp at these times is within range.
Evap is clean, new cabin filters installed.
Condenser fins clean and unobstructed.
Charge is within spec.
I chalked it up to just being really hot outside and the system working as it is supposed to during the described conditions.
Around town, it works well, with no issues.
But now I wonder.
I haven't checked the condenser fan run time, but the compressor on/off cycling Super77 describes is on parr with what I have noticed.
Fan clutch has good resistance when cool, and roars with every cold start up. Haven't pushed it around when hot, I'll try that to see if there's a difference.
I'm wondering about the condenser fan now.
Might look for test procedures on it, or where/how it gets its signals from?
^^I’m positive it’s the auxiliary/condenser fan with everything accounted for (assuming there is no leak anywhere especially in the expansion valve). If the condenser is not adequately ventilated, it causes the AC system to run on excessive pressure, and when that happens the refrigerant is not able to travel through the high pressure line back to the evaporator to generate cool air.
One test I do is run it idle, observe the fan speed/frequency of it turning on. Get a garden hose on standby. Once the AC vent stop blowing cool air, spray water (mist pattern) on the condenser from the front and observe if the AC vent will blow cool air. This helps you identify two things, either the fan or condenser or both components are not optimal anymore.
But now I wonder.
My FSM does not mention a condenser fan at all, so I'm also wondering how to test it.
OK, thanks everyone. Bear with me - I did some more testing today with different results :bang:.
To recap:
99 LC100 (2UZ-FE), A/C mostly fine but weakens on hot (90F+) days. Never fails, just loses some ground when it's really hot. Ran the FSM's procedures on two different days (plus a few tips I got here). Tests were done at Max AC, full fan, air to dash vents. Assume all original A/C components. The records say the PO had an 'A/C Service' at the dealership a few years ago.
TestDay 1, 88F ambientDay 2, 82F ambient
Engine condition3x ~5 min runs, ranging from idle to 2000 rpm for the gauge test1x 15 minute run at 1,500 rpm
Static pressure (engine off)101/101 psiNot tested
Running low side pressure35 psi (spec ~21-36), within rangeNot tested
Running high side pressure251 psi (spec ~200-213), overNot tested
Vent temp @center50-53°F, ~36° differential31.9-35.4°F, ~45° differential
Sight glass testBubbled ~18 sec then clear = correct charge (per FSM)No bubbles at all = overcharge (per FSM)
Compressor clutchCycling normallyCycling normally
Evaporator inlet line (firewall)Cold and sweating, not frostedCold and sweating, not frosted
Condenser fan behaviorCycling on/off with compressor clutch, spinning slowlyNot sync'd with clutch, Running almost continuously, noticeably faster/louder
Misted condenser with water mid-testNot doneDone, no visible effect
Have not tested pressures today, but bottom line:
  • When ambient temp is high, system slightly underperforms but suggests normal charge
  • When ambient temp is a little lower, system performs correctly but suggests overcharge
I have not checked the evaporators, but I did confirm the condenser is unobstructed.
What says the 'Mud-mind?
I think I would wire a switch straight to the condenser fan for test purposes.
Let it run 100% of the time for a while, also I assume you're including driving cycles and not just testing sitting still.
I bring this back around because I just have mine on a switch and use it as needed (really hot days, or traffic). haven't tested with a thermometer
but there is a distinct drop in temperature at the vents when it's on.
I may have missed it somewhere, but what are your engine coolant temps during all of this testing? I think it'd be pretty important to make sense of what temp your engine is operating at when you are in a 90+F outside temp day.
Is the vehicle just in park while you are testing vent temperatures, and hoping it will be cool on 90+F days?...,Or is this testing happening when you are driving and air is moving across the condenser allowing it to cool properly ?
Welp, this certainly isn’t helping things:
Weird that Uncle T puts a filter access door on the 99 evaporator box but then ships that model year with no cabin filters. I don’t think it’s even been opened 😲
I’m gonna vacuum it out and re-test.
I agree with this, when idle testing if coolant temperatures hit 198°F and higher that’s when the AC go into high pressure and stop blowing cold air. So it does really come down to how the engine is cooled (radiator, thermostat, fan clutch) and condenser (electric aux fan).
This turned out to be most of our problems when we were hunting for colder air on hot days fwiw.
How old is your radiator? When I changed mine there was quite a bit of "stuff" collected between the condenser and radiator that was impeding air flow. The A/C has been blowing much cooler since. A few years ago I added a condenser fan to assist with A/C cooling and it helped in stop and go traffic. With 100F+ days it's usually running when I stop my car and it makes people think that my engine is still running. Both together and I have good cold air on demand.
