A/C recharge for 3FE
Arizona
The A/C in my 92 now blows dry. I guess it's time to recharge the A/C. Has anyone used the kits you can buy at the auto parts stores? Or am I better off just taking it to a shop?
You can self-recharge any vehicle that runs with R134a.
A 1992 80 runs R12. Take it to a shop, that's one of the only ways you can recharge your system, unfortunately.
Shops tend to tell you that R12 is "unobtainium", and charge a high price for it.
As far as I know, anybody can buy R12, you just can't put it in yourself. So, you have to find "somebody" else who is certified to do it. Thats what I heard from my dads mechanic friend.
To use R134 all you need to do is change the receiver drier (the dessicant bag is specific to 134). Evacuate as much of the old oil out of the system, install the oil specific for 134a. Change all the o-rings on hi and low side and you should be good to go for 134a. If its R12, you MUST have it done by a licensed shop to keep it R12. Converting to R134 should be no big deal.
No, you must have a license to purchase, R-12, and a host of other refrigerants.
There is tons of info on this subject on both mud and the 3FE Yahoo group.
Running R134A in a system designed for R12 can sometimes result in poor cooling.
Yes you need a licence to purchase R12, but it's a matter of filling out a form and mailing it in.
R12 is available on ebay all the time and gets more expensive as the weather gets warmer. Right now it should be cheap.
Shops charge buco $$ for R12 because they can.
Some R12 replacements work OK like Freeze12. Cheap and easy to do.
John once again you come to my rescue. Do local autopart retailers sell the Freeze12?
I got mine on ebay. I was going to stick with R12 and get a license, but it was hot out and I was pressed for time. I bought a complete conversion kit which included new schrader valves, 3 cans of Freeze12, 1 can of oil, 1 can of stop leak (which I didn't use), and a filler hose with a valve. Did that 2 summers ago. Blows real cold, like freeze your knuckles on the steering wheel cold.
My shop told me they had to order R12 at five buck an ounce. Does the 3FE hold two pounds?
Freeze 12 in my 92
Freeze 12 works great. Compatible with R12. Recommend not changing to R134. I went that route and couldn't get it to cool as good as R12/Freeze 12.
That's exactly what we're talking about. The shops want you to think they have unobtainium, and WILL charge a high price for it.
eBay is the way to go on this.
R12 is awesome. My brother's car has an R134a system (1997), and just had it recharged. Still not as cold as my truck with the original R12. :D
Okay let me see if I understand. I can get a refill kit of R12 off of Ebay. And I cant get it at Napa or Autozone correct?
Not that I'm aware of.
And you have to have a license to handle it. Like many have said above.
Ok found it on Ebay. Lools like a can get a whole kit for about 40.00 bucks. Way cheaper than my shops price.
I bought a similar Freeze12 kit from eBay. Have a question though, when replacing the schrader valves does that vent your A/C to the atmosphere? Never worked on the A/C before so not sure how it works. Thanks!
yes it does. You will need to pull a vacuum after changing those im pretty sure.
