No I wasn't. I was at idle speed with the A/C set on high. What difference will this make. And if it does make a difference can it be amended?
It's 85% if you are converting from R12 to 134a but my 94 is already 134a. And if you are converting you should off load all of the R12 first.
Sorry for the delay with answers, geting the boat ready this weekend, detailing.
When you have time (no rush; you won't hurt anything by leaving it), do it again with the rpm's at 2k, or whatever your year's FSM says. Low side pressure will be significantly lower than at idle; it will be easier/quicker to recharge, and you should be able to get the sight glass to run clear without the low side pressure going above the FSM recommendation.
Cheers,
Curtis
