A/C drain questions
Dubai
Website
jumeirahparts.com
Okay so I have had the infamous evap box water leak for a while now and it hasn't really bothered me but I have recently noticed that it has been causing my RH sway bar mount to rust.
What methods do you recommend to clean out the drain tube of debris and what size rubber hose will fit over the drain tube for an extension?
My bracket was pretty rough looking too. I stuck a tube on there, probably 3/4" and attached with zip tie. Ran the tube to outside of frame and it exits in front wheel well, directly to the ground. I think i did this the first weekend we owned the truck as a temporary fix. At the time I intended to come up with something a bit better but after 18 months and 20k miles it's worked perfect so I've just left it be.
Before putting the tube on I used weed eater line to clean out drain.
And good advice on cleaning up the bracket and painting it or fluid film or something similar.
Cruiser Garage makes a kit to extend the line as well.
There probably sold out because I bought 3 of their kits last week. I bought the 2nd for a spare and the 3rd I am going to use it on my GF's Land Rover.
The kit does well but, the manual didn't make much sense until I carried it under the LX with the kit.
Do you have the kits in hand? If so, any chance you can measure the diameter of the barbed fitting?
A Pex elbow will work. I posted a thread about it
Measured the OE hose ID (88539-60080) which protrudes from the firewall yesterday using some calipers. 8.8mm (relatively .348")
I'll be adding this as a kit to the website soon as it has been requested by several customers.
I'll be using barbed fittings for 3/8" ID hose- I had installed a 1/4" barbed fitting on my truck and an OE hose clamp but decided to make it cleaner with a 90 degree fitting and some fresh hose.
More details to come soon...
