Calling A/C gurus, I recently completed my 1HDT Diesel swap and wanted to charge my AC. All my system is the original R134 system from my 1997 LX450, except the compressor, which is the R12 compressor from the 1993 Diesel.
I purged the oil from the R12 compressor and replaced with PAG46.
I pulled a Vacuum to -30hg and left for a couple hours, no loss in vacuum.
I charged about 12oz of R12a (Equivalent to 30oz R134) (R12a NOT R12)
I am seeing 130psi on the high side (R12a says 70% of pressure of R134, so seems close, but a little low)
I am seeing 26PSI on the low side (Low side with R12a stays the same) while compressor is running
No bubbles in the sight glass
I have never charged my own AC before. My vents seem to be blowing quite cold, but what temp should I be seeing on a thermometer?
The compressor runs for about a minute then cuts out. when the compressor cuts out, the low side pressure rises to about 45psi in about 15 seconds and the compressor kicks in again for about a minute (Dropping low side back to 26 PSI)
I just want to confirm this is correct operation?
Please don't make this a R12 vs R134 vs R12a debate. In Canada R12/R134 are not available to consumers without a HVAC license.
Thanks
Thanks
