97 LC Radiator Removal?!?
Whats the deal with having the nut on the grill side of the two black radiator brackets. Do I really need to remove the grill, lights, etc and it still looks like its too close to the trans cooler to fit a socket on? Is this OEM or did the previous owner F'k up? Why not just put the nut on the opposite side where everything else is? This is pretty damn frustrating.
It's factory. Some have been successful leaving the grill in place using a 1/4 drive swivel & extension. I had remove the radiator but it was easy.
you can loosen things and reach in with a wobble extension IIRC if you're careful.
there are several threads with decent pics that helped me a couple of years ago when i did ours. search is a friend here.
You don't need to remove the grill or lights. Remove the fan and fan clutch. Disconnect all your hoses. Remove all the mounting bolts and it comes right out. It's a pain in the ass but you can use a wobble to get the bolts that are semi-behind the lights.
Get the shortest wobble you can find and several lengths of extenders.
A wobble socket will work but the grill is extremely easy to remove - I think it's just two screws and then you can give it a good clean.
Oh sorry - yes the grill is super easy. I was thinking of the headlights and the crossmember. No need to remove those, but yes the grill must come out. Easy to do, though.
Robbie told me to just loosen the bar that goes across the top and move it slightly out of the way. Then you can get a gear wrench down there and loosen it easily.
I had already taken the low road and pulled everything off the front end and fought it. His suggestion sounded very reasonable though.
I did that & it got me nowhere. Each rig is different though! Just start removing s*** until you can get to them. Took me ~3 hours start to finish.
Search some of my posts from a few months ago. I did a radiator replacement and i think i made post with some comments about the replacement. I think i found it easier to remove the trim pieces and have good access to the nuts. It looks like a simple job, and it is. But it is important to do a quality job. You should search for my post. It points out stuff when it was fresh in my mind. There are simple things that are bad if you do a crappy job. The black plastic fan shroud is really critical to be in the clips on the bottom of the radiator. I had a Koso from the PO. The clips were not holding the shroud well and while wheeling hard the fan hit the fan shroud destroying my radiator. This was while i was up in the Beartooths miles from anywhere while wheeling alone. This was a real problem.
Thanks guys!
I ended up removing the blinkers which allowed me to 'LOOSEN' the headlights. There was still another plastic black bracket that ran over to the corner lamp tucked way up in the fender. No way to get to it but it allowed me enough room to get a 1/4 socket on it only to then discover only one side nut came off. The other side even after using PB blaster was rusted on there so I got a 1/2 drive and a 12mm impact sockets and let her rip! R.I.P POS!. 3 new silicon hoses are on and the new rad is ready to go in. I might just zip-tie those two upper brackets this time :)
I had the same frustrating experience with those two nuts when I changed out my radiator. My momma wouldn't approve of the language I was using.
If you have dual battery trays, it makes things about twice as difficult. With just one, you can shift things to the opposite side with the shroud, etc, but with two then you can't do that. This is another way in which you may need to vary your approach depending on what's up there. I also had a big fat cable or two over to my Blue Sea winch switch...:grumpy:
