Short time member, long time LC lover here
I recently found a FZJ80 that is fairly local to me I'm looking into buying, and figured the opinions on this forum would help make my decision of whether to go with it or not, and what a good price would be.
For context, it's a 1996 80 series with triple lockers, and has 199k miles on it. Current owner installed a 3.5" OME lift, has new 315/75/16 KO2s, and has done a handful of misc repairs to prolong it's life. Including castor correction brackets, rear panhard bars, LSPV delete, replaced all coolant hoses, new belts, replaced the oil pump cover gasket, distributor ring seal and front main seal, as well as bypassed the rear heater core. The body is in mostly good shape, with the main rust being on the rockers, which he has a replacement for the passenger side that I could have installed. It's lived it's whole life here in Michigan, so having some rust isn't a real big concern to me. Has a decent size dent below the drivers tail light, but the light housing is not broken. All electronics work, no lights on the dash, and the interior has the usual wear a vehicle with 200k miles would be expected to have.
I'll occasionally use this as daily driver for now, but also have a second (much more fuel efficient) vehicle once the "new car high" has worn off, then it will be used mostly as a trail rig. I just don't want to fall into a mechanical nightmare trap if I can avoid it.
Thoughts?
Thoughts?
Definitely pass on this one. There will be another
