96 cruiser fuel pump issues
Utah
Hoping to find a little help I have a 96landcruiser that shut off all the sudden like it's not getting fuel I have tested all relay ports and fuses including the plug directly into the fuel pump and they all have power relays test between 60 and 80 ohms the car will crank over and try to start on starting fluid so it has spark but for some reason the fuel pump is not kicking on when I try to turn the car on I have replaced the fuel pump with a brand new one also replace the battery with a brand new battery and I am at a loss for why the pump is not kicking on also noticed that the oil pressure light check engine light and battery light are not coming on when I turn the key to the on position any help would be greatly appreciated as I am stumped on what it could be thank you anyone for your input anything at this point is worth looking into
... also noticed that the oil pressure light check engine light and battery light are not coming on when I turn the key to the on position ...
No power to the ECU, fusible link, bad wiring connection, etc.
I was told to check the am2 fusible link however I've not been able to locate it I thought it was coming directly off the positive battery post but that turned out to be the am1 fusible link. ECU doesn't appear to have any burn marks or melted wiring going into it tested all connections I could think of with a voltmeter and they all appear to be getting power but for some reason the fuel pump doesn't seem to be getting told to kick on when I turn the key over even though there is power right at the fuel pump
When the check engine light wont illuminate the problem is usually the EFI main relay or circuitry.
You can also manually turn on the fuel pump by jumping FP to B+ in the diagnostic connector under the hood.
Good luck.
Good luck.
Sweet I'm going to replace the efi main
Relay and see if that fixes it.thanks
I also forgot to mention the circuit opening relay may cause the issue too.
Often times you can swap in another like relay to test
I attached the wiring diagram for you.
Awesome thank you very much I am going to check both of those first thing in the morning I had previously tested the EFI main relay and it was showing 73 ohms from previous info I was told 60 to 80 ohms means the relay is still good however at this point it's worth replacing just to see if it works LOL
A real basic test of the 3 fusible links:
FL1/AM1 (small ring terminal): if the dome lights work it's good.
FL2/AM2 (grey connector): if the CHARGE lamp lights when you turn the key to ON, then it's good.
FL3/FL MAIN (large ring terminal): if the brake lamps work when you step on the brake pedal, then it's good.
Thank you everyone all of your input has been a super huge help a lot more than I've been able to track down online and in the Haynes manual every other schematic makes the am2 link look like it's further up there wiring harness and that's why I've been having such a hard time trying to find it I'm going to pick up a fusible link from the dealership and start with replacing it and then if it still not getting anything I will replace the EFI relay and if that still does nothing then I will replace the open circuit relay and hope that with those three parts i solve the issue :-)
I'm not a fan of shotgun part replacement. I'd use a meter and diagnose the issue.
With the exception of testing the fusible links I have tested the EFI relay and it had 73 ohms so I'm assuming it is still good still haven't Tracked Down the open circuit relay though to test it
I had an intermittent lack of fuel issue recently which turned out to be a failing (but working intermittently) fuel pump relay. I believe if you take the plug off the fuel pump relay (in the DS wheel well, accessed through the engine compartment) and jump from the #3 to #5 terminals with a test wire and paper clips and your truck runs and starts you might have a bad fuel pump relay. To ID the #3 and #5 terminals, looking at the plug which goes into the fuel pump you'll see there are 6 spots but only 4 wires, like this:
1 2 3
- 5 -
When I jumped from 3 to 5 my truck started up and ran great. So, I figured my fuel pump relay was failing, although it did test fine per the FSM. I had already verified spark, and there is another test I ran by jumping 12V+ to one of the same terminals (3 or 5, I can't recall) and heard the fuel pump running fine. So, I felt like I had verified the fuel pump was working fine, the filter was not the problem, the EFI and circuit opening relays tested fine and worked fine when jumped, so I replaced the fuel pump relay. Problem solved.
The fuel pump relay was $85 at the Toyota dealership but I see Amazon has the Denso relay for $55. If I had known that I would have gotten the Denso, but I also didn't want to wait a week.
I hope that helps. Good luck.
to update my situation I replaced the fusible link with a brand new one from the Toyota dealership upon replacing it and turning the key to the on position the check engine light was back on my dashboard however the fuel pump still did not kick on and when I try to turn the car over to see if it would start by chance the battery started to smoke and the fusible Link blew again and the check engine light no longer comes on the dash when you turn the key to the on position again
I have a new fusible link on its way to the dealership for me to pick up again however it appears as though I'm going to have to track down some type of short possibly happening in the system that is making the link blow for some reason
And track down why the fuel pump still is not kicking on going to be looking into that open circuit relay that was mentioned above and hope that and the new fusible link resolve this issue
yay exciting news four hours of tracking down wires to the wiring harness and finally found one wire rubbing against the motor that had worn through and was shorting out fixed the wire and the Beast fired right up issue solved thank goodness
Thank you again everybody that replied on here to help me try to solve the issues I appreciate all of your time
