95 vs 96 question
Washington, NC
Hello,
I am considering a few fzj80's. One is a 96 with the locking differentials a few more miles and a few more dings. One is a 95 with no locking differentials, and immaculate. I will be using this as a daily driver and to do a little light towing. Probably will never see really heavy off roading. I saw something about the 95 having more potential for engine problems than the 96. Is there any truth to this? Is there any real advantage to having lockers if I don't plan on heavy trail use?
Thanks for your help.
They have the exact same engine, I don't see how that statement could have any basis in reality. The only difference that I know of is full OBDII compliance. If you read that on this forum, please give us a link.
Hello,
'95 and '96 are almost identical. The only difference would be diagnostics--'96 was fully OBDII but I think only about 1/2 of '95 was OBDII compliant (someone correct me). I'd go with the '95 from what you're describing. You won't miss the locking differentials unless you do serious, technical offroading. It's still a very capable vehicle without the lockers.
Yes, the '95 and '96 are mostly the same. Interior etc... Mine is a '95 and is full OBD II as I have a Scan Gauge hooked up to monitor all the fun stuff. Go with what you like, they'll both do what you want them to...
I've got a 95 w no Lockers... drop it in 4low and it still does more than other rigs out there... but man I'm achin to put on some lockers before long... errrr
Well what is few more miles, and how bad are the dings? I will not argue that 1996 is better than 1995 but the way Toyota is doing business is that they implement slight improvements every year, so just not to get anyone upset I personally think that 1997 is better than 1996:) Anyhow, test drive to hell out of it, make sure you take it to at least 70MPH just to see if you get any vibration and stuff, I have made that mistake with mine, and month later had to drop 500 bucks on new ball joints witch I understand since I bought it used. Once you drive it you will know whitch one to choose. Wont hurt to take it in for compression check also. Locking Diffs, is better to have them and don't use them, then need them and don't have them. The choice is yours. Cheers.
Thank you for your replies. I did not read the thing about the 95's on this site. It was on auto trader or something and it was not even a sentence, just a "check mark" by potential problems. You can read anything on the internet. That's why I joined here, because you guys seem like the authority on the subject.
Anyway, am going off for some test drives today. If luck is on my side, I might have some more questions about my "new" LC.
Thanks agian
95/96 virtually identical, even most of the 95s are OBDII.
In general you want the latest version of the vehicle you're looking for - obviously. The important thing is that for all extensive purposes the '94-'97 Landcruiser will cost the same to maintain. My point being, a well taken care of '95 could save you thousands of dollars over a used and abused '96. Regardless of the year differences.
Do a search on youtube for some fj80 videos - this is how they get dinged up. :) Unless your absolutely positive of the condition of a vehicle, it may be wise to stay away from an overly wheeled 80. Especially the ones that guys over rev to make it through obstacles (i.e. mud) - the conditions for doing the fan clutch mod - where rev like hell to get through something, then sit on the other side while you wait for others.
Well we are not buying that truck, bluejack is. So let's hold our horses and see what he comes up with and he better have detailed photos!
There was a thread a while back about the 95 OBD II complience and it seems that nobody could find a '95 that wasn't OBD II complient. But because it's a year earlier than required, most DEQs treated it and test it as an OBD I vehicle.
I can only think one of one significant difference between the '95 and '96. There's a potential issue with the A343 tranny having to do with reverse and this seems to have been slowly fixed between '96 and '97 with late model '97s having the full fix and '96s have a part fix. But it's hard to tell how big of an issue this issue. Only a few people here have commented on it.
If both vehicles were indentical, I'd want the newer one, but if one is significantly in better condition and lower mileage, I'd rather have the lower miles and better condition vehicle especially for a daily driver. And I would have zero issues with buying another '95.
As long it's not a '94 or earlier with that ugly interior, older engine and giant boat anchor of a transmission.
:D :D :D
My manufacture date is 2/1995, and I am OBD II compliant. I believe that is as far back as OBD II compliance goes. My understanding is that 1/1995 manufacture date is OBD I compliant. There are other changes which occurred between Jan and Feb of 1995 as well. As far as I know, most of the changes between 95 and 96 were cosmetic. My info is that 1fz engine was identical for 95, 96, and 97 (US).
As far as lockers go, there are a lot of places you can go without them, and I go a lot of places in the Idaho mountains without ever locking my diffs. Only a few times have I ever found myself "needing" the lockers but then, I can't say I go around looking for places to "need" them.
On an unlocked 80 series, you are in "full time" 4wd, and you still have a 2 speed transfer case which automatically locks the center diff when in low range, and with the addition of a simple dash switch available thru Slee, you can also lock the center diff in high range.
On a locked 80, it is not recommended to turn the vehicle while locked, especially the front, so the application of the lockers is usually brief (here is where I unintentionally offend crawlers) unless in snow, which is where I use them most.
I say, get the cruiser whose drivers seat "buttprint" matches yours the best :D
Don't know where you live but in Colorado, the emission standards are more demanding for a 96 than a 95. If the engine and systems are actually identical, this would mean a 95 would have an easier time passing emissions tests.
co hc nox
95--20 2 4
96--15 1.2 3.5
Based on your stated use of the 80, look for the best maintained/condition/mileage one.
no go
Well,
I am starting to find out that you have to move fast when looking at low mileage cruisers. 2 have been sold out from under me. I did test drive a 95 but I think the seller overstated the condition a bit. The pics looked good enough but had some rust, power seats broken, back door wouldn't open, radio shot, uneven tire wear, and basically overpriced for condition.
The search continues! That's half the fun I guess.
I took me several years to find the right one. Looking on and off. Fortunately prices are lower today than they were when I was looking, but low mileage good condition cruisers are harder to find.
Also while higher mileage cruiser values have dropped like a rock, lower mileage good condition cruisers have somewhat held their value somewhat...because they are getting rarer.
I personally would hold out till you find the right one. Treat it like a wife...make darn sure you picked the right one, because you'll be stuck with it for years to come, you will spend all your money building her and maintaining her and she will be harder than hell to get rid of if it doesn't work out. Oh and the older and more miles on her, the less use you'll get out of her....the Land Cruiser I'm talking about....LOL! :D
Brian894X4
...I personally would hold out till you find the right one. Treat it like a wife...make darn sure you picked the right one, because you'll be stuck with it for years to come, you will spend all your money building her and maintaining her and she will be harder than hell to get rid of if it doesn't work out. Oh and the older and more miles on her, the less use you'll get out of her....the Land Cruiser I'm talking about....LOL! :D[/QUOTE]
truer words have never been spoken!
i did buy a rig that didn't have lockers and i wish i had them, but ther has only been 2 times in the last two years that they would have been handy. set your standards and don't give in - my 2 cents.
another thing that is may be worth mentioning that i learned in my quest for a cruiser was that '96 and '97 FZJ's have the SRS (supplemental restrain system) so you get dual airbags, don't know if that is worth anything to you but is was to me.
and another another thing worth mentioning is make sure that the birfields are in good condition. i made a mistake and bought a rig that had a blown birf and thought to myself - sure i can do that no problem. ha, it wasn't a 'problem' but it sure wasn't easy. working on these rigs is fun but you will have plenty of oppurtunities by just keeping up on the general preventitive maintenance. remember - your buying a rig that is 14/15 years old and most of the previous owners out there haven't done much more than change the oil). so if you can avoid major projects that's a bonus.
good luck with the hunt :cheers:
