Hey Guys,
Its been a while since I posted so I figured I'd share what I have been up to with the 80. Over the past year I've been doing a number of little projects and some larger ones. So far its been a great rig. The plan for this project is to try and make as much of the add on's as possible look factory or at least flow with the factory form of the truck...a bit of a "sleeper".
For starters went through and did a hand full of the more common mods
Then moved on to some larger projects:
Pulled off the factory running boards and welded up a set of rock sliders. I ended up getting a little fancy with the bender to do the kick outs in the back which ended up turning out pretty good in my opinion.
- Pulled the diode out of the coolant gauge to read true temp
- 20k Cst silicone in the fan clutch (ended up finding some of the real deal viscous drive silicone fluid!)
- Center diff lock switch
- Fixed the stripped gearing in the seats
- Various other leaks, little issues, and baselining
