Parting Out 94 fzj80 in NC
I need a couple of things for a 94.
- tan Headrest with plastic insert
- driver seat adjust plastic handle
- driver side mirror with motor
- AC Drier bracket (the one under the front fender)
- Dome light with plug
- fuel door
- hand throttle cover (circle button next to the fuse box)
- power steering gear box
I have most of this stuff, I can reply with a PM this afternoon with details, I’m currently busy for the morning though.
Do you have the steering box still?
After looking through the multiple pages on this ad it seems like you have a lot of stuff available. In looking for a hood, black if possible for a 97, but color really doesn't matter as long as its straight. Still learning the 80 series and unsure what years are interchangeable with others. TIA.
Hoods for all 80 series (91-97) are the same. I have several, but none in black. I would be surprised if you could find one in black that actually matched your truck, black was a bad color for fading and clear coat peel. If your interested in another flavor, send me a PM
thanks. sent you a pm.
  • Like
Reactions: AJR
I have hoods and upper hatches, not in white though. I probably have a set of center caps but none are in great shape, they would need to be painted to look good.
Thanks once this shelter in place is lifted could I come by and check out what you have? Have two 80s I need stuff for.
It’s fine with me if you come by now, but I understand that everyone feels different about the current situation and interprets the order differently. When ever you want to come by is good with me, just shoot me a pm and I can give you an address.
Hi there, I'm looking for the A/C Suction pipe which is the low pressure pipe coming out of the evaporator core mounted to the firewall. See picture below:
Looking for parts for my 94
gray door cards (all 4)
2 center air vents
Fan shroud
Rear wheel well carpet covers )and trunk carpet (preferably gray)
