94 FJ80 Engine Dies
Park City
I’m at my wits end.
2 months ago got a misfire, changed plugs, #5 looked the worst. Ran fine after that.
2 weeks ago we had a cold spell, truck started a misfire for about 5 seconds on startup then would smooth out. Over the next week it took longer to smooth out till it would misfire even after heating up but not as bad as when cold. Pulled the plugs and #5 was bad looking (Brown and corroded looking). Swapped it with #1 with no change in misfire. No other evidence of any kind of a head gasket leak.
Decided to pull the throttle body and intake and go ahead and replace the injectors which were stock. Replaced the injectors with remanufactured/cleaned/tuned ones and also replaced the connectors that all broke. Replaced the vacuum lines under the intake, valve cover gasket and spark plug seals also while I was there. Cleaned intake and throttle body and reinstalled with new Toyota metal crush gaskets.
Plug wires NGK, cap and rotor are about a year old and look great. No EGR, it's been gone and been running fine before this. 155K on the truck and very well maintained.
Truck will start up and run fine with no misfire for about 10 seconds then slowly go down in idle till it dies. It was setting a code 41 for a TPS signal. I replaced the TPS with no change. I tested the voltage at the TPS and it has ground, 12v and 5v. Cleared the codes, tried again, same thing. I sprayed carb cleaner all over looking for a vacuum leak and found no change in RPM. Engine has good ground. I now get a solid blinking CEL when I check for codes. This is the last thing I did. Need REAL advice. In Park City UT……anybody nearby...com’on SLC!!!
I'm getting a beer
I’m at my wits end.
I'm getting a beer
A few other items:
Wire loom by the EGR pipe was fine, no burnt wires
I hear relays kick in from the drivers side dash area that will change the idle RPM up but then it goes back down (?)
TPS was not an issue at all before I took the intake off to replace the injectors (?)
I capped off all the vacuum ports from the intake with no change in performance
While it was running i wiggled all the injector plugs, other plugs, wire harness and other things with no audible change
After it heats up it will run and not cut off but it's still low RPM and rough
I set a sledge hammer on the bumper.....no change
My thoughts:
Feels and sounds like unmetered air but I can't find any vacuum leaks. No rtv sealant needed for gasket right?
If I mistakingly plugged a vacuum line in the wrong way would it cause all this?
2nd beer
I would take a look at that plug again, and do a compression test. If everything looks good, maybe it's time to adjust the valves? It's possible you have a vacuum leak at the intake, but you shouldn't need to silicon the gaskets. Might be a good idea to check ignition timing as well, just to be sure it hasn't moved.
Check the air tube. If its good then test the crap outta the iac. Mine would go bonkers after a few cycles. I've got a post in here from a couple years back with the same issues. Except mine did this at busy intersections.
+2 or 3 for unmetered air. Just a thought, could your dipstick seal be bad or do you have a non-OEM replacement without a seal?
Update - Still have the same issues
Here is some more info
Took the intake off again, got it down to 20 min.
Inspected the vacuum hose routing - all good
Sealed the throttle body and intake with RTV sealant this time to eliminate any doubt of a vacuum leak in those places
Tested the fuel pump - working
Checked the timing - within range
Rubber intake hose is new. Got it about 4 months ago
Tested the MAF or VAF meter - I got resistance and it changed when I moved the vain - THA-E2
Tested voltage to ECM from TPS. In range at the ECM - G/B/B wire
Not setting any codes now for some reason
Idle goes back occasionally right before it dies. Relay kicking in making the idle go up is the Fuel Pump Relay.
Cold start, it runs out beautifully then dies. After it heats up it just dies, sometimes takes longer to die than other times.
Throttle is barely responsive or sloppy after the closed loop startup. Once the ECM start reading sensors it Shatz the bed. Not driveable.
Seems like a lot of gas smell in the tail pipe emissions. Running to rich I suppose due the ECM not getting data correctly hence ....it dying
It's fixed!!!!
Here is what I did next:
Thanks to Jake (A Rusted Development) in Heber I got a known good MAF, TPS, Fuel pump relay and ECM off a donor 93. Swapped out these parts to eliminate any doubt with these systems. All parts swapped and no change, truck still starts then dies. Grrrrrrrrrr......
After pretty much eliminating everything else I decided to start all over again and tear out the aftermarket injectors. I went back out to Jakes and he sold me a couple used Toyota injectors to swap out my #5 which I suspected as causing the initial misfire that got me into all this. I cleaned up my old Toyota injectors and put on new seals. Put it all back together (for the 3rd time). I was reluctant to start it........It's 8:30pm, key in ignition, standing outside the truck, bumped it over a couple times to get the fuel in the rail, it sputtered........and ran. Backed it out of the driveway, ran up Parley's Summit to Lamb's Canyon and back down the mountain with a big smile on my face.
I hope this saves someone else from my misfortune.
The aftermarket injectors were half price (Clue #1)
The aftermarket injectors looked totally different (Clue #2)
The aftermarket injectors had a Toyota part # that cross referenced with my stock part # (Clue #3)
The aftermarket injectors came with a note "These may look different but are exactly the same specs and will work in your vehicle" (Clue #4)
They DID NOT WORK IN MY VEHICLE!!!!!
Hey gang, just thought I would share my code 41 issue.
I’m behind the wheel of a 94 and picked up 28 and 41 codes after my recent 3000 mile trip at lower altitudes than my normal 8-11,000ft routine driving.
Code 28-running rich can often be the motor choking, so I cleaned the air filter until I get a new one, code vanished.
Code 41-throttle position sensor, engine bumbling at low rpm etc. I tried all the norm-checked vacuum hoses, connections, checked wiring for abrasions, reset the ecu a few times, scratched my head a bit. Sometimes extreme change in climate can cause tubing to become loose fitting. Tried these things when it was warm outside (65) cold outside(35) engine hot, engine cold.
The throttle position sensor is obviously in question so what does it do? Simply tells the ecu where the throttle is positioned. It is just a simple switch that turns when the throttle is pulled. I messed around with my hand throttle, locking it slightly pulled. It ran better but not ideal. The tps has an adjustment range so I tried adjusting one way(without hand throttle) , ran poor. Adjusted the opposite way and it ran fine but then would die at a stop. Through all this the pedal had some lag time, very slow to activate the throttle.
Hmm, what are the chances that over the last 25 years and 260,000 miles that the braided cable simply stretched? It’s just an oversized shifter cable for a bicycle... bicycle shifting is adjusted by 1/2 milimerers to find the sweet spot...next I adjusted the throttle cable and positioned the tps to match. I made a few minuscule adjustments and found a sweet spot. I don’t know if this is a permanent adjustment and only time will tell. Today I ran some extra long errands and put 100 miles on my adjustments and the girl just purred along. No bumbling or complaining of any sort. If this adjustment doesn’t last I will report back. If nothing else this will get you out of the woods and back to grandmas house. I have a replacement tps sensor, wires and plug en route but I will continue to drive with my existing knowing that I have a replacement in the cubby within reach. Cheers
