About a month ago I joined the 80 club and now I'm in the process of doing pm stuff. My transmission has been acting up as it shifts from 1st to 2nd gear. It either has a second or so lag while shifting or slips out momentarily after it changes gears, but only between 1st and 2nd. I've checked the fluid level. It was initially a bit low, but I filled it back up and it is still having the same issue.
Could it be debris? (Haven't had time to change the fluid and filter yet.) Is it an electronic issue or mech. adjustment that is needed? Is it worse than the previous thoughts?
Next question. My 80 idles at 1200-1800 rpms. Yes, I know that that is way to high. (Yes, I also realize that at colder temps it initially runs higher to warm up, but it doesn't come back down to regular rpms) How do I adjust the idle? Also, could this have any effect on the trans issue?
You all rock! (I'm waiting for a great answer AND simple solution....
Blue 60
Blue 60
