93 center diff locker question
Beaumont, texas
i have a new to me triple locked 93. It was never used off-road, I've known the car since new, and I believe they put it into low once just to see what happens.... That being said, when I engage low nothing happens, the light on the dash doesn't even blink. When I try to engage the front and rear the lights blink, but nothing happens. From prior research on here, I know that actuator can stick on the center, but I wanted to try and shortcut some steps if I need to just replace. The front and rear are going to be troubleshot next. Any advice would be welcomed, and yes I do plan on adding the 7 pin bypass.
your front and rears wont lock unless the cdl locks, so don't even bother with the front and rear yet. sometines driving in a figure 8 can help free up the actuator, or a gentle hit on the t-case with a rubber mallet
Do your figure 8's on loose ground. Also, while you can replace the troublesome parts before following one of the threads here to try cleaning them first, accessing and removing them is only hard the first time. I felt much better about the success of cleaning them after my skin scraping/knuckle busting/wrench dropping/where-the-hell-is-it/dirt in the eye first time than I would have if I had just thrown money at them. If cleaning doesn't work, replacing will be easy.
Listen for relay and/or motor noise when you move the lever to 4LO.
There are lots of threads about your issue here in 80's Tech. My mind is too early morning foggy to walk you through it, but check this out: CDL Sensor/Switch
*I think there's mention of Beck Arnley replacement unit for under $20 somewhere here.
