92 rear locker search
New Hampshire
I have been researching for about a month on different lockers but have been unsuccessful in getting opinions on what would work best for my 92 80series. If I purchase an aussie locker and have the rear end locked all the time versus ARB or any on air locker that is only accuated when I need it, will it create problems putting street miles on it 3-4 days a week, NO more than 30 miles each day? Any feedback or advice would be greatly appreciated. I have been successful so far doing my own upgrades/repairs. Are some lockers not really a do it yourself? Thanks again.
Derek
personally, I consider 30 miles a day a fair amount of road time...for that reason, I'd look at either the ARB locker or the factory E-locker.....with your 92 semi-float rear axle, I suspect the ARB will be easier...but neither will be cheap.
IMO, a fulltime-type locker is better suited to a rig that is more dedicated to the trail...
Aussie Locker
Derek
We estimate that well over 80% of all Aussie Locker installations are daily drivers. There are certain handling changes that are present with an automatic locker but you get used to those in the first 25 miles or so. And there is a click in a turn that you may, or may not hear. But the 30 miles a day present no unusual operating conditions or potential for wear for the Aussie Locker. And most of our customers install the Aussie Locker themselves.
There are lots of threads on the 60 forum regarding Aussie & similar on a daily driver. Cliff Notes/Spark Notes summary:
Worse handling in wet/icy/hardpack snow, especially in a lighterweight truck, or with a shorter wheelbase. Mud tires and similar also exacerbate the effect.
A careful and attententive driver can learn to handle all of the above (similar to driving a lifted truck).
No handling differences on dry pavement.
If set up right, noise is minimal.
Install is easy, and far cheaper than ARB/e-locker.
Huge improvement off-road.
A number of 60 owners are using them as a winter DD and are happy with the performance.
My suggestion is to read the posts, and if it sounds good to you, go for it. Worst case is you take it back out and sell it for a small loss.
I'll say it:
Bang for your buck: Aussie
Buck for your bang: ARB
Buck for your buck: Retro fitting an e-locker or full axle swap.
Thanks for the Help
Thanks to all of you for your input. Being new to the Offroad world I find myself quite apprehensive when it comes to making decisions on what I should or should not do with upgrades. I have to say all of my friends have jeeps and just out of compitition between toyota/jeep, they help a little but, they still want to have the most capable rigs in the woods and would like nothing better than getting me stuck and being able to say their jeeps pulled out a Toyota. I want to do whatever I can with limited funds to make sure that doesn't happen. Thanks again to all of you. Derek
Can a 93 or newer rear axle be retrofitted to a 91-92? Would it be a direct bolt-on? I am interested in rear disc brakes as much as a rear e-locker. It would be nice to kill those two birds with one stone.
Hijack-
Since we are on the subject of rear axles, can someone explain the difference between a Semi-floating and Full-floating axle?
in a semi floater the wheel bolts directly to the flange of the axle shaft, the drive force and the weight of the vehicle both travel through the axle shaft.
in a full floater the wheel bolts to a hub that rides on bearings and a spindle, taking the weight of the vehicle, the axle shaft only carries drive torque,
Full floaters are usually used on heavier trucks because of their higher weight carrying ability, that feature of a FF axle is not really usable on a LC as it's usable pay load is no where near high enough to break a SF axle, one handy thing about a FF is that if you break an axle shaft if you can get it out you may be able to limp home without an axle shaft, where in a semi floater that wont work. pretty rare situation as usually if you have axle shaft problems (e-locker twisted splines) removal is difficult.
wile technically it is an upgrade to go FF but not enough of one to really make it worth wile on its own, if you want disk brakes and the E-locker then those are your upgrades the FF axle is just an extra bonus.
You can retrofit an FZJ80 rear axle fairly easily. It is a bolt up application. A local friend has my old rear 94 fullfloat unlocked axle in his 91.
Full float rear axles have the load on the axle ends on the spindles like a front axle. No load is carried on the axle. Semi float axles have part of the load at the outer wheel bearing and the rest of the load is transfered along the axle to the center differential.
I would never put an autolocker in a daily driven vehicle if I intended on driving that vehicle in snow or ice. Granted I've never tried it in an 80 but I did in my 60 and it only lasted 3 months. I couldn't stand driving it that way. And since the original poster is from NH I would assume they get inclement weather. I wouldn't recommend going that route. I'm a big fan of ARBs. They are fast to activate, reliable if set up correctly with care given to routing the air lines, and the carriers are actually an upgrade over a Toyota carrier. I have the elocked axles right now. I've been satisfied with them so far but I anticipate needing to upgrade to the ARB carrier should I decide to go about 35" tire size. And with the factory elockers you really need to anticipate when you are going to need it as they sometimes take a long time to engage.
