92 FJ80 Overheating
Tucson , Arizona
I'm new to this. My first question: I bought the '92 a few months ago. On a recent 100 mile trip I lost a few gallons of cooling fluid even though the gauge indicated in the (high) normal range. It was steaming from the overflow but it does not appear to leak anywhere. Can it be as simple as just the radiator cap?
Start with a search and look in the FAQ section.
Check your oil...what does it look like?
Probably not just a radiator cap issue. It sounds like it could be a Head Gasket, but with out additional information it is hard to narrow things down.
Good luck and use the search function!
Bummer. Mine was doing that and it was the head and headgasket. Get a radiator pressure tester (free rental at autozone) and go from there. Could just be a leak but testing is needed first. Don't jump to conclusions with the "bubble test" air will be in the radiator for a while after running that low on coolant. A cylinder leakdown tester is what I used to be 100% sure the headgasket was toast before tearing it down.
WELCOME!
:flipoff2:
X2 on the Pressure test.
Thanks. Oil looks just fine. Despite the 181k it does not seem to burn any or leak much oil at all. I replaced the radiotor cap today. The seals on the old one looked worn out and crappy and did not seem to seal real well. I will give it another long run tomorrow and if the problem persits I'll go with the pressure test.
Really looking forward to a head gasket change...NOT.
Have you looked at the PHH (aka Pesky Heater Hose), buried deep under the intake manifold above the starter, could be leaking. How are the rest of the hoses and the heater core? That coolant had to go somewhere.
However it could have been low to begin with. It may be a good idea to do a radiator flush and fill, new thermostat, hoses, etc..
Baseline the system and go from there. Some great write ups on the coolant system maintenance process.
I looked through a lot of the threads and FAQ. I gathered that a '92 3FE does not have the PHH. Is that correct?
Started it up this morning and it was showing a larger white plume than I would expect when it is cold out. It also left a wet spot under the tailpipe that feels like coolant. I did the "bubble test" and it continually bubbles a little.
I guess I'm hosed. I'm tempted to fix the HG myself but it seems a little daunting. However for the $2,000 or so (guessing) I can buy a lot of cool tools.
Also, would it be smarter to buy a reman head from SOR or have a valve job done locally?
You are correct. The PHH's are found on the 1FZ-FE's.
You are justified in a shopping spree of tools :D
Take that head to a local machine shop, ask for a quote on a valve job and pressure test.
Don't know how much a head from SOR is but your 3fe head at the local machine shop should be way under $400.
good luck
I always forget the 3fe is PHHless. My bad.
I never did the pressure test on a 2F that I had with similar symptoms. First, check the thermostat; make sure is not stuck closed, next the radiator; verify is not clogged, and finally the fan clutch. I found that my problem was a combination of things, the radiator was partially clogged, and the fan clutch was in bad need of clutch grease. After cleaning the radiator and putting silicone grease in the fan clutch, the overheating was gone. That was the reason I have no need for the pressure test.
If your oil looks milky, that's when water/coolant mixes with oil; you have a head problem. By this time, I would definitely do the pressure test. If the coolant goes to the cylinder, you may have some white smoke coming out.
BTW, Bienvenido!!! = Welcome!!!:flipoff2:
I had the same problem last summer. Did a pressure test and determined it was my radiator. Since I didn't want to buy an aftermarket plastic radiator, or spend big bucks on a brand new oem metal radiator, I had my original one flushed & rebuilt. Never an overheating problem since.
SOR is Specter Off Road in the LA Area. www.sor.com Not the cheapest but I have never had a problem with their stuff for my '77 40.
I'm gearing up to do the cylinder leak test next weekend. I think all the water disappears through the tailpipe. It's a lot of missing water and I dont see any leaks in the system. On the other hand, all the sparkplugs look the same. Not sure if that tells me anything??
