91 Value
Hello, I bought a 91 a while back. It has 240,000 miles and is in generally pretty good shape. My buddy bought it from the first owner in Palm Springs and then drove it 100,000 miles. It has never been abused, no rust, no dents. Paint is getting faded and carpet is wearing a bit. Seat is also a little worn in typical spot. Runs pretty good. I have a parts list costing about $1200. All the typical stuff. Cdan hooked me up on that. I cant work on it myself so I have found a shop here in socal (The Toy Shop) in cypress. I figure it will be about $2000 in labor. Maybe a bit less. I bought "grandpa" for $2500. I am planning on going forward unless somebody can talk me out of it. Is it worth "restoring" a 91 or just sell it and find one with less mileage? I like the 91-92 the best. Im not really interested in newer. 80 series anyway... I own a 100 series.
Thanks,
BC
When your talking about parts, what are you going to be replacing?Mechanically is the rig in good shape? What are your plans with the rig, what will you be using it for? I have a 92 with 270k, i am the original owner, and no matter what I wouldnt replace it. it means more to me than the money i would get out of it.
Go ahead and do the maintenance on it as long as you realize you will have put $3,200 into a 16yo truck with 240,000 miles on it and that it is still just a $3,000 truck after you pay to have all that work done by a mechanic.
If you like the truck then that is all that matters.
-B-
what exactly are you doing for $2000 to a truck that runs well??
also, what are you going to do with this thing? if you own a 100 series i can't think of much the 91 would do better. is this for dirt roads so you don't sweat the body of the 100 or do you plan to build it up?
-B-
X2 My thoughts exactly.
In addition, you know some of the history that sounds encouraging. I think we all have to make that call sooner or later about our rigs. The fact is they are not getting any newer. One has to ask, how much is it worth to me?
Personally, I have invested a lot in a 96 80 with 225 on the clock. Makes no sense in the "pure book value" arena of thought.
I tend to invest a lot in stuff that is cool to me, and I really don't care what value others put on it.
I'm still looking to replace my cherry 88 Cressida, built up '64 Ford Thunderbolt Fairlane, '57 Chevy PU, and on and on.
Sounds like you found something that does something for you. Go for it!
Thanks fellas, My plan for the 91 is to use as an airport car and general beat around rig. I work in aviation and travel alot. I would park it up in Spokane WA to use to run between the airport and my house in Montana. Its roughly 3 hours one way. Then as a rig to use to beat around on the old logging roads, hunting / fishing, etc. I will often have three or four people with me. It has to be highly reliable though. I like the 91/92 because of looks and simplicity. I dont want ABS, airbags and all that crap. I dont want HG problems. I dont want leather. I like the looks of the 91-92 best.
Some of the parts are a complete tune-up kit, complete front axle kit, complete brake kit, all hoses under hood, front wheel bearings, shocks, rear lift struts, wipers, antenna mast, and filters.
I see 62s for sale in socal for 10,000. Why is a 62 worth more than a 80?
A 10k$ 60/62 would be one heck of a cherry rig.
Some folks think the 60 series was the last 'real cruiser' and everything after that was built for soccer moms and net-weenies.
After driving a 60 for a year and a half, I'd almost agree with them- if it weren't for how much the 80 kicks @ss off-raod.
The best way to describe it is 'soul'. The 60 series has it, the 80 (and I LOVE my 80) doesn't.
Sounds like what almost all of us that have purchased used have done to baseline the maintenance.
If I read this right, you'll only have ~5500 wrapped up in a car that should last at least another 100k with proper care and feeding. Sounds good to me and I do all my own work!!!!! (except alignments)
that seems a high labour quote for that work. i'd go elsewhere. those trucks are far from rocket science. that is their charm.
there are no rear struts, just 4 shocks. otherwise your parts list looks reasonable but get your wheel bearings from a bearing shop not c-dan (love dan but i suspect he won't argue that rare exception to the rule).
are you replacing the front calipers in that brake kit? if so, go to the 93+ calipers (rebuilt not new and from a local shop) and rotors and the 100 series brake pads. they are bolt on and you will improve your stopping power significantly.
if you are going to that much trouble and expense, check the compession first.
assuming the compression is good, I would instead of doing the job you are doing, go a little bit more radical. get the head pulled, all the carbon removed from the pistons, do a valve grind, a small head shave to boost power a little and get the entire intake system.egr tube and injectors/fuel rail cleaned properly before i would spend that kind of dough. a valve grind is not that big a deal on a 3FE compared to a later truck. putting the truck back together afterwards would involve the tune up, valve adjustment and at least half the hoses so you would be achieving very significant efficiency and getting a much much better truck for your money at the end.
as far as the shocks go, if you are going to all this trouble you might consider deferring the shocks for a while and then adding ome medium springs, ome damper and bilstein stock replacement shocks. It will give you 2" of lift and improve your logging road ride and clearance considerably. you should be able to get the springs used here for a good price if cost is an issue.
do all that, and I think you will have a pretty decent truck. still a slug but not so much.
good luck
Thanks, sorry lift struts for upper tailgate. It just falls down.
Yes I was thinking full brake with front calipers. Will the newer rotors work on the 15 inch tires? I didnt think they would.
Grandpa does have new shoes. BFG ATs. If I have to get new wheels and tires, its just more $$$$
93 and up calipers and rotors will owrk on the 92 trucks.
I do have am rims on mine but still have 1/4" of clearance from the caliper to wheel.
My take is changing every day. Some days I want to park it, others I want to keep it forever, others I think it needs an appointment with a sawzall. Then again I just about 600 in parts into mine last month (all new bearings, front and rear axle rebuild, brake calipers........) Have no regrets here.
Dave
You know, I paid $390 to pull out, rebuild, and reinstal that stearing mechanism thats bolted to the frame, plus a tune up:D . I don't think you should be paying that much:eek: . It's a friend that lives near USC.
wait a minute... I got a deal, RIGHT?:o :eek: :crybaby:
:cheers:
Where are you located? Many times if you join your local Land Cruiser club, you will find many an apt hand to be lent. There have been 5 birf jobs in my driveway in the past 2 years.
Dave
I live in Long Beach now working. I have great facilities but am unable to work on it for a variety of reasons. I would be willing to pay somebody and/or trade out shop space.
