91 80 drum bake ?
I have the RD153 ARB air locker in my semi-float. Check out pages 22-23 for a better description of how the C-clip system works with the locker. I use ECGS for thirds. I send them in a 5 gallon bucket, they regear/install the locker, then ship it back in the same bucket. They may have one already built if you call, best prices and warranty in the business. Toyota 9.5 Landcruiser Gears, Install Kits, Carriers, Spider Gears - Precision, Yukon, Lockright
http://store.arbusa.com/Assets/file/RD153i.pdf
Thanks for the help I've found torque specs that I needed. There are also options for c Clip axles. Eaton Dif makes a detroit locker for it which is what I wanted.
FF axle would be awsome but I'm into this one for just new parts. And it has the removable rear cover which has allowed me to spin the axle to a drivers side drop relatively easy.
Are you sure? I have a full floater 9.5" in my Tacoma with a Detroit, but it won't work for the semi-float. Detroit Locker for Toyota Land Cruiser 9.5" with 30 Spline Axles, Full Float ONLY (225SL-124A)
Edit: Nevermind. " Axles that use C-clips must use "C" model " *For 1991 and newer axles, larger carrier bearings are required: 2 x Timken LM603049 & LM603014*
**For C-Clip applications, you must remove the right hand bearing cap to remove the cross pin bolt.**
I have also seen lockers for the full float only on sites like lowrange, marlin, and others for full float only. Not sure why they would advertise stuff for only one side of the market. Best to go to the people that make them to find out what they actually make
I wish it was that easy, this is a semi float drum brake axle from a 91. The axles come out after removing the drum, and the c-clips near the diff and all that is left is the plate. Looks like the bearing is pressed in the axle tube aND the bacing plate prested over that. The 4 bolts on the flange come right out they are not pressed in. Tried smacking it with a rubber mallet but nothing with budge.
Yeah, so re-read my post and then read your final solution...kinda the same thing huh?
"Remove the axle shafts as you normally would on a semi float. Remove the drums themselves and there are 4 bolts holding the backing plate and brake assembly into the tube."
And it was only 4 bolts holding your backing plate and brake assembly onto the axle tube...and a little rust.
Anybody know the torque specs on rear dif studs?? My guess would be about 60-70 ft lbs but didn't really know if there was actually a spec.
54lb-ft how about that google search engine?
