91 80 drum bake ?
Foresthill ca
Hi, new to this site and trying to get some help. Tried searching google and pirate and mud with no results.
Breifley explain my stuation. I'm using 80 axles in a 85 runner. The front was easy after getting hellfire knuckles, but my question is about the rear axle. I'm using a 91 non abs with drum brakes. I have the axle disassembled down to the housing and backing plates. My plan is to spin the housing 180' so that the diff is on the drivers ide instead of passenger side to clear the 4runner gas tank. I haven't done it yet but I will need to notch the flange on the axle so That the diff can be swapped to the side were the rear cover used to mount. I will also need to change the studs around as well.
The problem I'm running into is no the e-brake cable will go thru the diff. How do I get the backing plates off axle tube so that I can swap them side to side in order to put the ebrake back to the rear of the axle. I'm familiar with mini truck stuff coming off with the axle, but not used to 80 stuff. Seems like the backing plate is pressed onto the housing.
I have a large shop press with a veriety of attachments. I just dont know the proceedure and dont want break something by removing them the wrong way. Any help is appreciated if you have expirienced in removing these backing plates with the intent to re-use them.
Thanks -matt
Remove the axle shafts as you normally would on a semi float. Remove the drums themselves and there are 4 bolts holding the backing plate and brake assembly into the tube.
I wish it was that easy, this is a semi float drum brake axle from a 91. The axles come out after removing the drum, and the c-clips near the diff and all that is left is the plate. Looks like the bearing is pressed in the axle tube aND the bacing plate prested over that. The 4 bolts on the flange come right out they are not pressed in. Tried smacking it with a rubber mallet but nothing with budge.
Will try to post picture when I get off work. I've wrenched on plenty of hilux axles but never any new cruiser stuff. this has got me stummped. Probly something easy I'm just overlooking.
It IS that easy. The backing plate bolts to the axle housing. The bearing is pressed into the axle housing. However, I do not believe the bolt pattern on the backing plate allows for the plates to be spun. Swapping left to right is probably possible.
I will try beating on it a little more maybe it's just glued on from never being messed with. I thought it had something to do with part #42137 on the end of the tube, looks like a retaiNing ring or something holding everything in place.
I have a '92 and replaced the rear axle with the full-floater from a '96. The retaining ring (42137) doesn't retain the backing plate as far as I remember. It was only the bolts and corrosion that kept it in place. Check with a dealer on availability of the retaining ring and if it IS available, cut it off with a wheel or a hack saw, then try whomping on the backing plates with a BFH and a block of wood.
10-4.
Can I even put a full locker in this axle with those c-clips that hold the axle shafts. Is there some sort of c-clip eliminator kit or something. If not then I will probly find something else newer model
When I rebuilt my rear axle on my '92 (semi float), I swear I had to use a puller to get what looks like part #42137. It was a pain in the ass to get mine out, used heat too.
10-4.
I have a '91 with an ARB locker in the rear axle, so yes. Take the axle and drop it straight down on the splines and the backing plate will come off. I put a piece of plywood on the concrete so it doesn't hurt the splines. You can also build an adapter for the press with tubing, but it's a waste of time. Just smack it on the ground.
My axle does not have the spindle like the pic you posted. It looks like the axle on the bottom of the pic that golgo13 posted.
I'm still confused on how a locker would even work in this with the clips inside the diff that hold the axle in. If you don't have these clips in when everything is installed there's nothing to hold the axle shaft in.
Not 100% on the locker selection, but you are correct in that you must have an access to get the clips in. If they (name your brand) offer one for a 91 or 92 then it has access for the clips.
As far as the conversion to a FF, it requires a housing swap to get the spindles, hubs, etc. For your application, not likely an option without heavy modification to the housing. FF don't have an access cover so flipping it like your doing would require cutting the back off and mounting a cover. I'm not aware of any eliminator kits for these axles. And my 91 got a FF out of a 97 and I haven't torn into the rear of my 92 so I can't offer much help on the backing plates.
Edit: I see now that the pic you posted is not a spindle axle, got to get kido put down to bed then I'm heading out to figure this out. Will try posting some pics if the BFH doesn't get me anywhere.
This is pic of backing plate stuck to the housing, the ring around the bering part #42137 and small plate behind it is what I believe to be holding this all on.
Here is a shot from another angle.
Probly going to try a few different methods that people have mentioned but if I don't see signs of things budging without cutting the ring I'll call dealership tomarrow to see if I can even get a new ring before I cut the old one as mentioned by golgo13.
On another note a spartan luck box locker will work, still looking into grizzly, detroit, and arb.
Leave it to the cave man method to work!!! BFH and a block of wood. A bit of rust had everything locked up. If I can get a full locker for this beast I will definatly be doing a full write up on this swap for a hilux truck since there is absolutely nothing about this proceedure on the inner webs
Thanks for everybody's input, I appreciate it. You may have helped me create some new tech in the area that I'm pursuing!!
I see now that the ring is like a sort of dust type seal that recesses into the back of the axle shaft.
I may be way off, but looking at the parts diagram against your picture, I think the plate you are referring to is actually the housing itself. I think it comes off at the spot I marked below.
Edit: looks like you got it just before I could hit reply. Good deal, glad you got it off. You will have to put up a few pics of the truck when you get it up and rolling.
Actually i scratched around a little bit in that area once the plate was off and I can see that it is part of the flange that is welded to the end of the tube. In the SF mini truck axles this would be the bearing pocket, in a SF 80 axle it's part of the housing.
The bearing seem perfectly fine with no slop or signs of wear, probly will re-use them with some new seals.
A little plasma work and welding on the diff flanges, swap the studs front to back and will be ready for mock up under the truck while I figure out the locker.
Do a search for "FSM" posted by a guy named Trollhole
You should be able to download a free Service Manual from his thread. It will list the correct torque specs and help you to learn a little more about the parts.
As far as eliminating the c-clips, I'm not sure it is possible, but others may have a solution.
TacoSupreme has the correct picture for the rear axle above.
Check with @arcteryx (Jason @ CruiserYard) about a decent condition full-floating axle and go from there. The full-floater with Disc Brakes is much easier to fool around with.
