Used some 80 grit sandpaper on the door to see how well it would strip paint using my new Dual Action sander. Did ok, but I think I will stick with wire wheels or sandblasting for stripping as it will take forever using this method.
Are you trying to get all the paint off (to bare metal)?
I've been using the same type of sander - a Black and Decker 5" round Orbital with 150 Grit pads, It takes a while, but I'm not sanding every bit of paint off either, I think a wire wheel might be too rough......
right now and I won't be done for at least another week.
Best part is that it's on both sides!
Assuming that all glass is removed, does it look like the headliner can be removed and reinstalled with no major snags?
Good to see you back! So, do you HAVE to pull the back windows the get the Headliner out? I really don't want to if i don''t have to.
BTW My 60 had rust on the Rear Wheel wells in the exact same place.
