Media 80s With Canoes
Photo/Video/Audio threads
Land Cruiser plus boat is a prime recipe for fun and adventure.
Make/model: Necky / Cruiser II (it's a giant kayak, obviously, not a canoe). Great boat for touring, trolling and bird photography.
Ease of loading/unloading: Cumbersome when I'm solo. It's heavy. The cleanest move is like a military press, but from the ground -- lifting the boat overhead along the side of the truck. Gravity makes unloading dangerously easy.
16’ 1968 Grumman Aluminum
Weight about 40lbs
Prinsu roof rack
Front tie down connected to bumper, same with rear. No movement along washboard dirt roads.
Zona
Weight about 40lbs
Prinsu roof rack
Zona
View attachment 1961508View attachment 1961509
Those Grummans are war horses, literally. Grumman used the same machines that they used to make airplanes in WWII to make the aluminum canoe, which was a significant upgrade, at least in terms of maintenance, over the wood and canvas canoe that was popular before the war.
We call the rocks that are near most of the portage landings in the BWCAW and Quectico "silverbacks" due to the decades of aluminum scrapes that gleam in the sun that they have.
Solid work.
Solid work.
Seen those rocks. A little rainbow flare added from the plastics too.
Or gel coat. :p
I am an old fashioned wet footer. I like the rubber boot option. I just get the boat close, get the stuff out of it that is packed so there are only two or three bags and then toss one big pack on my back and then lift the boat out so that it really only touches water. The other person carries the other pack and the rods and paddles and makes sure we don't lose the dog. You can cover way more water if you know how to portage efficiently.
That said, I have seen some amazing things on the trail. Watching a marriage implode while hubby drags the $2500 kevlar canoe, fully loaded, of course, while the wifester pouts, down 300 yards worth of rough trail is a sight worth seeing at least once in your life. :hillbilly:
I don't know that much about canoes but I know a little. Is that 16 foot aluminum canoe seriously only 40 lbs?
Weight about 40lbs
Prinsu roof rack
That sounds like kevlar territory to me more.
17' cedar strip homemade job...
That's problematic rope on. You need a belly strap in the event of a sudden cross wind or you might find out what happens when the canoe slips off the side and gets run over and jammed into the underside of your 80. I have seen it develop from behind and I can tell you it's one of the more alarming things to witness, especially on a long and high bridge where there is no shoulder. Pretty sure a sphincter muscle does make an audible whistle under the right circumstances.
Otherwise, great looking tribe, truck and boat. Is that a Jensen inspired design?
Weight about 40lbs
Prinsu roof rack
More like 70 lbs or more, depending on the model.
Alumacraft made a lightweight aluminum that was around 50 pounds but they are hard to find and not great hulls for tripping.
Don't judge too hard. It is a quick, 2 mile jog to the lake. Low speeds and back roads gets us there and back without issue. I'm waiting to order the proper roof rack for said belly straps.
Plans came from Bear Mountain Boats: Wooden Canoe, Kayak and Small Boat Kits and Plans
Turned out nice...
1961824
Strap to rack/cradles and bow and stern lines. Also leave leave line attached to bumper but tuck under wipers so you don’t forget or drive over a bow line that is attached to your boat.
Friend of mine who got learn about composite boat repair the hard way. He also learned about attaching racks to cars and about bow and stern lines.
Damn, that's a Nordkapp. Probably the most famous kayak design of all time.
The straps and rope are stronger than the boat in case anyone was wondering. :p
Probably better the rack gave way and the boat looks OK, which is the money end of the calamity.
Regardless of how many other straps there are when tied to the roof, the bow line is critical. It is the first visual indicator while driving that things are shifting or about to go south :oops:.
You cant see it in the photo but the the kayak needed some serious structural repairs. It turns out that the owner was quick learn at glassing and gel coat matching and now operates his own kayak repair business.
Solid work.
100%, you're right, it's a mini battleship, hahaha. The rivets and sealing of it are so well made I could probably put on my viking hat and start ramming paddle boarders.
Zona
Or gel coat. :p
Same
I would need to know more about the boat to give you an honest opinion. Who made it? What sort of outrigger does it have and why does it have that? Any clue on a model?
How much are they asking?
16' Seda scout kevlar. Turned out to be in better shape than I thought. Thanks for the tips!
