80 won’t start
Queensland
Hey guys chasing some information as to why my 80 won’t start.
Story to it is went through a water hole out 4wding got stuck in the hole and was running in the puddle for 15 minutes got snatched out and as It was on the way out the car stalled got it out and wouldn’t start only would start under a jump from another car
got it home and changed all the filters and oils while letting it dry out few days had gone past and it starts and runs but then when you take it for a drive it won’t start cranks quite slow but the doesn’t start.
when I leave the for a couple of hours it will start again but then do the same thing and won’t start.
alternator is charging pumping 13.8 whilst running
Had the battery on charge and does the same with a full battery.
Also pulled the starter motor off and cleaned it out was full of black carbon dust
1hz n/a diesel
if anyone has and idea as to what is going on.
Cheers
First the information you've provided is somewhat confusing. You'll need to clarify whether the engine will not 'Crank' (turn by use of starter) or won't 'Start', actually fire up and run?
Time to break out the air compressor, blow all the relays underhood dry, use a brass bristle brush for any corroded terminals you see, and finally -add some dielectric grease if you have some.
Pull the battery terminals, ground lugs, positive stud on the starter, all multi-connectors underhood & do them all too.
Yes, it’s time consuming & alot of work, but it’s simple & cheap.
And you’ll be better water-resistant the next time you get in some deeper puddles with all the terminals greased, and the likelyhood of any running ‘quirks’ goes down, bigtime.
13.8V at the battery with engine running is a bit on the low side. Rev up the engine a bit (say to 1500rpm) and you should see near 14.4V. Ever replaced the brushes etc on the alternator?
Given it's a diesel, a lot of the 'electrical' issues of a petrol don't come into account.
Was it dirty water or mud you were stuck in and how deep was it? Salt or fresh?
If it starts fine with a jump, then I'd suspect the battery. Are you jumping right across the battery terminals or the donor ground cable to the engine hook and the donor positive to your battery positive lug? How old is your battery?
cheers,
george.
cheers,
george.
Thanks for the reply mate.
The water was muddy fresh water also the water was at the top of the wheel arches.
Jumping straight across the battery
Battery would only be two years old.
bushes on the alternator have never been changed when I’ve had the car
no worries mate I’ll have a look and pull some stuff apart.
Thanks mate
Engine will crank but won’t fire/start just turns over.
Very strange as I leave the car for a couple hours without starting it will start first go. So I take it for a lap around the block and will come home turn it off and then it won’t start straight after that.
I am taking mine into the (Yotamasters) mechanic tomorrow morning. I have a very similar condition. The battery appears to be fine, so I will let you know what comes up. Cold starts don't appear to be the problem and I have recently put in some fuel additive to see if its just old gas (sitting too long)
That will be great thanks mate. So strange as the car will start fine and then foes for a drive then turn it off and it won’t start again
So, by "doesn't" start you mean it cranks fine, just won't run?
Again, folks, this is a diesel, so it'll have different issues than a 1FZ...
cheers,
george.
cheers,
george.
yes cranks fine but won’t run. After time the cranks are quite slow.
Sometimes it will start and run, then I take it for a drive and then turn it off and it won’t start again
Well, being a 1hz, there's no fancy electronic injection junk like on the new V8 tdi's. So, all the 1hz needs to start is fuel, minimal glow, and good crank (and air).
There's is more than likely a device that controls the fuel for start/run/stop. Little motor contraption that connects to the injection pump stuff. Maybe that device is failing to operate properly when the vehicle is hot. That would prevent fuel from being injected and would be your no start situation. If it goes to stop when you are running, then the engine will stop/stall as well.
Would pay to pop into the diesel sub-forum on this site and post up there, you'll find more folk that are familiar with the 1hz.
And slow crank would likely imply your battery is not too healthy. Again, you should see about 14.4V at the battery with engine at say 1500rpm or above.
There's also likely an oil pressure sender that is connected to the fuel motor contraption that will cutoff the fuel if it detects low oil pressure. Worth checking it's wiring/connector/functionality.
cheers,
george.
cheers,
george.
Ok no worries mate thank you
