80 will not start, pls help
Found a worn wire in the fusible link. Replaced it and now the headlights and OBD2 work but engine will not even crank, stereo will not turn on (it did before) rear brake lights and turn signals still not working.
1) Get DMM out.
2) Use DMM.
Or if you want to keep poking around in the dark.
1) Tighten battery terminal hardware.
2) Try starting it.
3) Grab another vehicle and a set of jumper cables, attach jumper cables to your terminals as if jumping your truck.
4) Try starting it.
If 2 works, you're done.
If 4 works, your battery was dead or is bad.
2) Try starting it.
4) Try starting it.
Batteries are new and my Dual Bat monitor reads full power and I have them on a trickle charge.
Gotcha, it could still be your terminals, however. Easy point to cross off. Mine got loose and I would get power as you describe but connection wasn't good enough to start. Different issue from yours though is that when load would get too high everything would turn off.
Optima red top...1/0 gauge wire running to side terminals with a terminal bolt, TIGHT
Food first!!!
Someone is there to party.
HUGE Shoutout to @NLXTACY and @jtwopark for coming through tonight and saving the day. The issue was in fact a faulty fuseable link, (more like a non existent fuseable link, because it was long overdue for a change). Definitely going to stock up on more parts thanks to Joey - OEM Toyota proucts offered by Wits' End.
Rear brake lights are still out/not working along with the rear turn signals, but that is for tomorrow. Gd Bless.
Kids check your fuseable links frequently.
-Sammi, PKP80
On days like this I am just proud to be part of this community!
