80 series front link system
Sanders
Is there any reason why a 80 series front axle can't use a jeep style long arm kit for the front link setup?
One long lower control arm with a Y mid way with an adjustable link to the top of the axle for castor adjustment?
Like Metal cloak or Rubicon Express long arm kits use?
Yes but you would need to weld on the housing for upper mounts. If your going through that trouble weld a mount on the frame and 3 link it. On the keeps it’s a bolt in deal.
I am by no means an expert in this area.
I have my LC apart at the moment and would like to cross this bridge before I put it back together.
I have been looking at jeeps on the Rubicon lately, and most of them are running a single lower arm with a Y to the top of the axle on both sides..
The link to the top is not for castor on a Jeep, but seems like it could be for a LC with out doing a 3rd link?
@jodo
It's a suspension design that sucks. It will articulate but gives lousy dynamics. At that point just weld a link bracket onto the frame for a real 3 link.
Now you must articulate 😉
As the suspension moves, the measurable things about it get bad very quickly. A three link can keep those measurements within an acceptable range for a greater range of motion
I always felt that if you were that serious about travel and wheeling then you should be in something other than an 80. Get a smaller vehicle with better aftermarket support that's also about half the price to maintain?
