80 Series Battery Tray Replacement, Aux Battery Tray, Washer Relocation Kit - NEW from Bump It Offroad!
Bump It Offroad
Supporting Vendor
CO/TX
How is your battery tray in your 80 looking? Gently used? Rough?
Have you been wanting to replace it with something nicer? Or add a second battery? Or a compressor mount?
Are you wondering how to relocate your windshield washer bottle for that passenger side battery tray?
Bump It Offroad can help you with all of the above!!!
Enter the Bump It Offroad replacement for the OEM battery tray. This will fit the driver side of USDM 80 series Cruisers and 450s.
  • 304 Stainless Steel
  • Will fit group 24, 34 (with spacer) or 27 Battery
  • Mounting Holes for Blue Sea 285 Series Circuit Breakers
  • Includes
    • (2) OEM Toyota J-Hooks
    • (4) OEM Toyota Flange Nuts
    • Stainless BIO Battery Hold Down
    • M8 Mounting Hardware
These are available NOW: Battery Tray (Driver Side) - https://shop.trimeki.com/collections/bump-it-offroad-accessories/products/battery-tray-driver-side
Next up is the passenger side battery tray for adding a second battery, or you can mount the MORRFLate TENSIX portable 12v off road compressor using our custom mount brackets. This includes mounting holes for Blue Sea 285 Series circuit breakers.
Made from 304 stainless steel.
For use with Group 24, 34 (with spacer) or 27 batteries.
  • Includes
    • Tray
    • Spiral wrap for AC Line
  • Optional Battery Tie Down Kit Add-On:
  • Optional MORRFlate Bracket Kit Add-On: (Compressor NOT Included)
    • (2) Custom mounting brackets
    • (4) M6 Flanged Mounting Bolts
    • (4) M6 Push Nuts
    • (8) M6 Washers
    • (4) M6 Lock Nuts
NOTE: Requires Washer Reservoir Relocation Kit
Available NOW: Battery Tray (Passenger Side) - https://shop.trimeki.com/collections/bump-it-offroad-accessories/products/battery-tray-passenger-side
Very nice.
I am having a hard time figuring out where you relocate the washer bottle to. Do you have a pictures of the above items installed?
I hope these pictures can help illustrate where this kit relocates the washer bottle.
It does require extending the harness to the washer pump, we provide wire and heat shrink tubing for this minor modification.
You can ignore the sensor and connector, we are going to relocate those and keep that space open for an isolator if we run dual batteries in this 80.
I run these in my 80. I have tried all the other options out there and these are by far the most secure option for batteries out there.
@OffRoadScott i can confirm a group 31 fits in the passenger tray but haven’t tried on in the driver. They’re a mirror of each other so I’m sure it would fit on the driver side.
Thanks for the pictures!
If these could accommodate a SC31DS group 31 from Optima I might be all over these.
I am going to check on this. You can see the 31 fills out the passenger tray fully. Maybe we will see if we can swap it over to the driver side in Moab and confirm fitment.
Will you have the battery trays available for purchase at CruiseMoab?
We are not bringing inventory, but these will be available to purchase online.
Now that you mention it, this might be a good time to bring up our show special for Cruise Moab!
Stay tuned...
Cruise Moab show special for battery trays and washer relocation kit!!!
  • Good for 80-series battery boxes (both sides) + washer relocation kit
  • Purchase all three and get 15% off!!!
    • Also applies if you opt for the MORRFlate brackets pass side option
    • If you want passenger side battery tie down AND MORRFLate brackets - also applies!
  • If you don't want to swing all three items - get 10% off.
  • Special ends 19 April at midnight.
  • Use the Request A Quote function on our store page, add all three items to your cart, and we will apply the discount and reply with your shipping cost.
  • Remember, we will be in Moab all week, so we won't be shipping orders until we get back!
I am looking forward to hearing if a group 31 does fit.
That is good to see/hear.
