We are having a warm November here in Northern California (about 75f today) so a buddy of mine wanted to take his boat out. His wife and daughters were out of town with their Suburban so I said no problem, it is only about 20 miles we will tow it with my 80. The boat and trailer come in at about 4000-4500 pounds so it is close to the limit of the 80. The 80 did really well in terms of handling and braking.
The problem I had was going up hills, I would start to heat up, and on one steep climb where I had to go up in second and for a short while first at full throttle, I saw 210f on the temp gauge. I did not hear the fan kicking in on the climb.
A little bit of background. My 96 80 has 180,000 miles on it. I put in a new 93-94 factory radiator in 2006 as well as a blue hub fan clutch. About 2 months ago, I replace the fluid in the fan clutch with the 6000 cst fluid, and I flushed the radiator and put in new Toyota Red last week. I get a big startup roar. I did a quick check running the engine at 3500rpm and saw no bubbles in the overflow. I also don't have any coolant loss.
Any thoughts? Fan clutch timing? Just not hot enough to get the clutch engaged? Early head gasket failure?
Here is a picture of the 80 with the boat.
