80 & 62 Build NEW VIDEO added
The manifolds are 02 C5 corvette stock manifolds. They do fine in a 60 series, too tight a fit in the 80. A side benefit is the O2 sensors mount in the manifolds, bung already there.
Full Auto Meter gauges including fuel gauge with fuel sending unit. Customer chose red back lighting. These gauges are accurate and well calibrated as opposed to going to the trouble to get the OEM C----H temp gauge to work. Same applies to OEM oil pressure. The speedo can be wired to the harness or to a GPS unit.
That means there would be plenty of room for them in a 55, right?...:hmm:
That is a cool feature of the speedo to go to GPS, nice find...:idea:
I'd have to measure the 55. I am not a technology for the sake of technology kind of guy but the GPS thing is pretty cool. May have to check it out :)
Lokar shifter and boot arrived, boot with LED shift indicator on right. Package on the left is all that is required to make LED work
First photo is DBW gas pedal from donor cut in two places.In the second photo parts on left have to be configured to match OEM on right
WARNING!!! if wiring scares you don't look at the photos.
Lots of wiring with a Vortec swap. All terminal ends are crimped and soldered. Double heat shrink protects wire from bending too tight and splitting
Stand offs allow VIN plate to be read
Stock gauges
stock gauges removed and 5/16 cut from the rear of the two larger rings
That looks really sharp Stan ....
Correction, it looks perfect
I love Griffin Radiator, they tell you 2-3 weeks and it shows up in 8 days. This is a direct fit FJ62 radiator I had made into an LS version. Swapped top tube and filler neck and added a steam port
Nice stuff, as usual! Looks like there's built in room for an intercooler :D
