Like to share my experience with this, I was the other person that purchased the gear sets from Radd Cruisers, have gotten them installed and been driving on them for a couple weeks. First of, I won't comment on the topic that @Will Van started. For me, I was after 3.73 gear sets and that's what I got.
I will speak to the experience of getting them installed and thoughts on how the trucks feels and drives compared to the 4.10s.
First some background on the 3.73 gears in respect to Toyota heritage. From my research, Toyota never installed these ratios in the HD 70 series models or the 80s which share drivetrains of 8" HP front and 9.5" FF rear. I believe the 60 series 9.5 are different and do not cross over to the 9.5 FF. The 8" HP came in other toyota models like the pickups and tacomas, so those gearsets are widely available.
So the 3.73 rear set has to be custom made aftermarket as that ratio was never sold by Toyota in any model, closest is 3.90 in the 200 series, which share the same R&P. Marks4wd used to be the main source for these, who probably got them from Drivetech4x4 also.
Here is another thread on it:
3.73 gears - https://forum.ih8mud.com/threads/3-73-gears.851573/page-2
I removed the thirds and took them to a well known toyota gear installer here in Socal. The front went in fine using a typical install kit. It is 29 spline so I had to purchase aftermarket flange as factory was 27 spline, contrary to @Radd Cruisers statement above.
They also said that the rear is odd ball and the pinion is 32 spline, which is discussed in thread above. Requiring 200 series bearings and seal, which are not very common and took sometime to source, otherwise everything setup per spec.
Now for the fun part....I LOVE LOVE LOVE how it drives now. More range through each gear, at 75mph I am cruising at about 2600 rpms versus 3000. Best of all it feels like I am in the power band much longer. With more engine load at lower rpms, the turbo spools up quicker, gives it more oomph down low.
I did some 4wd low wheeling, wasn't anything extreme, can't say I felt much of a diff. Later when I need a rebuild, I'll have Georg put the low gears in it.
I am running 33 inch tires, with the low end torque of the diesel, you don't sacrifice much performance, with some skinny 35" tires it might be even better.
So there you go.
