79 Fried Igniter
Kind of. I only get spark from the coil when turning the ignition switch to and from start. Not while holding the key to start.
I went back and re-cleaned up all of the electrical plugs yesterday. Today I'll do the checks in the manual that I posted above and verify that I have good grounds and proper continuity through the wires from the ignition switch to the ignitor.
I'll also check the distributor pickup as per the YouTube video.
Check your air gap on the distributor signal generator. Mine was definetly not in spec. I couldn't even get the smallest feeler gauge I had in there.
I adjusted mine out to mid tolerance of 0.305 mm
I adjusted mine out to mid tolerance of 0.305 mmView attachment 2265427
Nice, I will check mine as well.
I double checked the coil and it measure 2.5 ohms so it was out of factory spec of 0.5-0.7. I was also not able to get continuity on the HT wire from the coil to dist. All of the plug wires measured out of spec for resistance as well and looked suspect. I ordered a new coil and all new wires (plugs and HT)
I checked to make sure the coil was getting power and it was. The igniter also seems to be getting power so now its just a matter of the right signals going where they need to.
Hopefully the coil and new wires solves the issue, doesn't explain why I was burning up traces on the igniter board though....:meh:
I had issues with my resistor bypass connected to an aftermarket starter not sure why, worked with the oem unit. You could try disconnecting it while trouble shooting.
I'm not convinced the USA coil resistance numbers in the excerpt from the manual that I posted are for our coils. I'm thinking my coil was swapped out for a non-US coil at some point because my ohm readings are in spec for the foreign coil and the fact that my coil has "use with external resistor" stamped on it.
I'm curious if your coil has the same part number or a different one.
My coil number is 90919-02083.
I tested my new Napa coil along with my Denso pictured and another coil a friend had. Both the Napa and no name brand had the same numbers.
Scratch what I said about the coil. It IS THE CORRECT one for our 1979 models and like yours, mine is out of spec. too. The Napa one is likely for a points type older distributor, hence the values and was mislabeled in their system as working on my 2/79 model.
Hope I still have the reciept😞
Update:
New coil and all new wires still no spark coming from the coil HT wire.
going to try going back to a stock igniter so see if that helps the problem.
I am going to try with another igniter which is known to be good.
After that I'm not sure, back track to points style ignition? I really don't need/want a long term solution just enough to move/drive/tests other systems of the 40. Everything will be coming out for a 2H in the coming months.
I just ended going with Oreily house brand
PN 2-5195
Yeah it measured at 0.5
I tested two of these from O'Reily's and both Ohm'd out of spec, along with 3 from Napa. :banghead:
Luckily, I ordered a stock coil replacement from the dealership. Hopefully, it shows up soon.
Did you get an original, working ignition to work?
Okay so I have a later 2F igniter/coil assembly. The chassis harness has slightly different connectors compares to the new igniter assembly. The chassis harness has a single spade connector that has a yellow wire and a double spade connector which has a small black/yellow wire and a fat black/yellow wire. The new igniter has 3 single spade connectors. each with black, brown and yellow wires coming out of each.
Chassis side:
new igniter side:
