Wanting to make sure we are the same page about a heat sink . In the attached pic. I am wanting to point out the gm ignition module is bolted to the aluminum bracket (using the bracket as the heat sink) also using heat sink compound between them. The longer the module is on without a proper heat sink the more likely it is to burn up. Hope this helps
Yeah good call on the heat sink. Just for clarity this is the current setup I have installed now. I didnt have any luck going the GM route. This setup is for an 81-83 22r.
I should have been a more astute reader. Hope I din't waste too much of your time.
No worries I can hardly keep track my self!
I had major issues getting the 79 stock dist. out of the engine and here is why...
I have not idea how this happens or if it was correlated to my ignition problems. After I finally got it out I checked the oil pump and spun freely and smooth using a flat blade screw driver. The cam drive gear also looked okay from what I could see.
The 77 dist dropped right in no problem. I lined up the BB in the window then mashed the dist gear rotor so that the rotor was aligned with the #1 spark plug wire on the cap. As per FSM rotated CCW until the points arced then tried to start it. It would cough and almost fire but when it did it seemed like it was fighting the starter and would struggle to crank.
I was able to get it started by sweep the angular position of the dist while cranking, I lost track of where it actually was after it was running. At that point I could do fine adjustments to lower RPMs down to where it would knock and up until I ran out of adjustment. I was not able to spot the BB i painted white while using the timing light, was this because the idle RPM was way too high?
I shut it down for a few min to track down an oil drip and when I tried to start again it would just crank and misfire like it was fighting the starter again.
Any ideas for dialing in this timing problem? am I off by a tooth on the dist? I dont think I am 1 revolution out otherwise I dont think it would be able to run at all?
