78 Gauge Cluster/ Electrical Issues
Mine seemed to read low, so i replaced it and got the same reading. I tested it with a mechanical gauge. Mine read 40 psi near the 1st line.
Oil Pressure gauge is now working!
Got factory power to my Fuel Cutoff Solenoid!
What is the plug in the picture go to? It comes out of same set of wires for Fuel Cutoff Solenoid.
Yep - carb temp sensor.
If temps are hot after shut down, it triggers a relay and turns the carb cooling fan on.
There is a sensor on the manifold that works with the carb fan controller. The sensor on the carb flange works with the emissions control and is for EGR.
Thanks. My carb must no longer have the sensor. I've read about the fan being a good thing to keep fuel from vaporizing. Do I need to come up with another way for the fan to turn on when carb gets warm?
Late reply but the carb temp sensor for EGR is screwed into the base of the carb on the front. You'll often find the wire clipped off and the sensor still in place but the holder (next to the holder for the idle solenoid connectors) also clipped off. Yours looks like someone cut off the holder - probably to fool a Smog Nazi at some point.
