78-79 Chevy 350
Montana
I have an opportunity to possibly pick up a running 78-79 350 for about $500 how much in adapters etc will i have to spend to swap it in if I decide to? Can i keep my 3 on the tree or will i have to get a new tranny etc. What about the wireing harness? I've looked through the threads and couldn't come up with what i was looking for maybe I'm just a dunce but any info would be awesome. TIA
Check out advanceadapters.com They have pretty much any adapter that you would want. You could hook up a 350 to your three speed, but if I was going to do it, I would wait, save up and swap in a four speed of some sort. Wiring is a non-issue. There are so few wires on a cruiser that old that you won't need any kind of wiring harness.
You can do the swap for cheap and it will be evident, or you can do it right and spend a good deal more.
looks like $1500 for engine and adapters, + my labor time + beers for my buddies = I need to get my tax return.
In a few months, I'm hoping to move on to an SM420 transmission and get rid of my H42 with adapter. I would track down a GM SM420 or 465, get Bob Firestein mounts, and I think Woody (guy who owns the board) sells or used to sell the transfer case adapter. If not, others do. If you want it primarily for the street, a Toyota 4-speed (H42) shifts better, but it lacks a low first gear. x2 on dumping the 3-speed...
You have a lot of other things to think about with it, too.
I like my three on the tree, and do a lot of trails and hunting I don't need that extra gear, just something to push it that I can get parts easily for. I live at least 60 miles from any toyota dealership and waiting days on parts in the mail just plain sucks.
so all i would need would be trany adapter, engine mounts, electric fans for cooling?
You can use a mechanical fan if you have the room. You should with a three speed. The labor is going to kill you if you don't have tools, welder, torch, grinder, etc. In the other thread, you alluded to not having tools...
I'm pretty sure my buddies can help me out on the labor end. one has a big shop where they tear apart and build up many rigs that shouldn't cost me more than a 12 pack I'm guessing.
engine, adaptors and such plus all the little nickle and dime stuff, plugs, belts, hoses, fastners,clamps,
drive shaft alterations,exhaust, etc. Easy to spend another $500-$1000 or more.
Curious-
What items/parts specifically having to do with the Toyota engine, have prevented you from operating your Land Cruiser when you have wanted to?
I have an sm465 with an AA transfer case adaptor. Haven't put it up for sale yet, mostly because I'm busy and was hoping for a local sale. (Polson isn't that far!) Wouldn't mind selling, but it's going to have to go for more than a run of the mill tranny would. I put a complete rebuild kit in it - sintered iron main shaft sleeves, new 1st gear (to eliminate the wornout rubber vibration hub), synchros, bearings, and seals. It has the AA adaptor and spud shaft for a '76 4-speed transfer case. It worked fine for me for a year or more until I went with the big bucks nv4500 and TBI. Been sitting in my shop since then.
PM me if interested and I'll make a decision on price. You would have to either buy a different spud shaft for it, or find a 4-speed transfer case. You'll also need a Chev bellhousing (if the 350 doesn't already have one), as well the other stuff people have mentioned.
There are several other options. Depends mostly on which transmission you choose to go with.
Also, wiring harness is a stretch of the imagination when installing a carbed 350. There are only about a half dozen wires to connect - pretty simple.
HTH
Does the $500 SBC have all its accessories? Alternator, water pump, air cleaner, etc.. That crap adds up fast. Your going to have to build an exhaust system too. AA has a water temp sending unit conversion so you can keep the Toyota sending unit. You might want to get that too.
I don't know what you included it your $1500 estimate, but don't forget about the clutch.
As others have said plan on at least 500-1000 in $.05 & $.10 stuff.
I ended up spending much more that I originally planned.
A Cheap Option
If you decide to keep the 3 spd, I have a front bearing retainer, and the plate you would need, using a Chev bellhousing. Got it with some other stuff I needed, just taking up space. Just an option. Al
