Is it possible to do a clutch replacement without removing the tunnel cover?
(A friend had bed liner sprayed on the interior of his rig with the cover installed. Removing it will involve a lot of tedious razor trimming around the bolts/washers and the cover itself.)
I was thinking the trans top plate could be loosened from under the vehicle and lifted up high enough to remove the transmission.
