77 PULLING LEFT
Canada?
I posted this in the 70 series thread, I'm trying to desperately address this:
Hello,
I'm having a drifting issue with my 77, it's leaf sprung in the front.
When I bought it pulled a bit to one side, then took it in for an alignment it drove straight.
I then had an issue and needed to replace a tie rod end, at this time I also swapped in the spare tire, I got it aligned, and it seemed to track fine at first and then that tire lost air, pumped it up, and it seemed to track ok, but has degraded quiet quickly. The drifting is bothering me. I took it to the shop today; they told me that according to the specs they've put in, it should be drifting right, but it still drifts to the left. And that because of this it must be a ball joint issue, or another replaceable part- this does not sound right to me because had it been this issue all along it never would have tracked straight before.
It's a 93 77, old man emu leaf springs and shocks heavy duty lift - new to me truck.
Tires are 255, 75, 16, with spacers. Tire pressure 35 psi.
I'm looking for help in figuring this out and figuring out what are the different components that would affect this drift, as I am not well versed in this.
- part of the problem here is that I don't know how the suspension/steering works very well and what affects what, the second part of the problem is the tire shop that has adjusted the crap out of the toe, but has essentially given up addressing the issue.
Does the pull get better or worse when you brake? When I've had issues with my truck, it was a caliper that had one or two of the pistons seized. Should be able to easily tell if this is the problem by jacking up each front corner and seeing if the wheel spins free or has drag.
If your mechanic is blaming it on a ball joint, ask him to show you where the ball joint is on a solid axle. :rolleyes:
I will try this weekend, I also got some feedback in checking the rear leafs.
Its probably screwed, let me save you the trouble. Just bring it over to my place and park it on the driveway. :)
Always tough to diagnose a tracking issue. As mentioned above try to narrow down when it happens the worst; accelerating, braking, just stepping off the throttle, steering left/right, check tire wear, etc, etc. Does it consistently pull that direction? is it typically the same amount of pull? Can you remove the wheel spacers?
Get under it and check every single thing that attaches the wheels to the frame; knuckles, u bolts, springs, spring hangers, any bushing's, etc. Bushings can be tricky as it is sometimes difficult to replicate the forces that driving a vehicle puts on that specific item while parked in the garage...
Good luck my friend, post up if you get it narrowed down.
Start with the easiest thing to check. Check tire pressure, if one is a bit off, it can pull to one side.
It will be washed, clay bared and waxed waiting for you in your driveway if a package with a reasonable amount of cash for the truck arrives at my apartment.
Typical land cruiser owners when it comes to buying its worth less than a discovery with a blown engine, when it comes to selling or for insurance purposes they Value their car slightly above Bin Abdullahs golden fleet.
