76/77/78 FJ40 Exhaust Manifold Heat Shield Pic Needed! Exhaust Manifold Insulator Heat Shield NO. 2.
Ackcruisers
MA
Can someone share a picture of where this heat shield fits on manifold for 1976/77 FJ40?
Toyota Part No.: 17168-61014​
EDITED: The heat shield is actually for a 1979-87 2F Click here
INSULATOR, EXHAUST MANIFOLD HEAT
I'm not exactly sure where it will mount.
Carb/Manifold/Exhaust Pipe Insulator
  • Exhaust Manifold Insulator Heat Shield NO. 2 17168-61010 click here
that heat shield is not for a 76-77 manifold, that is a later heat shield that mounts on the rear horn by the firewall on US manifolds that had the EGR tube coming off the rear horn.
the US earlier version had the EGR coming off the main part of the manifold so the heat shield was just an "L" shape
I'm not sure what manifold your overseas rig has or if it has the provision to mount a shield.
Thanks for this. Exactly the information I needed. My intake/exhaust manifold can be seen in images below.
the 2 holes in the heat shield go to the 2 threaded holes on the rear horn.
it will work on your manifold but isn't the correct one.
in the heat shield pic above you need to rotate it 90 degrees to the left and it will attach to the manifold
there is another shield that goes on the front horn but unsure what it looks like with the non US air cleaner
View attachment 2641035View attachment 2641038
hey PAULS :)
can't
paul
drill out and Tap threads in the BOSS';s of non threaded deletes he has going on there ?
its roughed in for the threaded holes it appears
It appears my rear manifold has plugs and no threaded holes for shield. I suppose I could carefully drill and tap but not sure the payoff.
I just found the link to the Toyota Parts Deal site that shows the image provided is actually for 1979-87 2F and as you said is not the correct shield. Click here
but without threaded holes, there is no way to attach a shield to the manifold.
The 17168-61014 shield appears to fit this type of exhaust manifold. @3_puppies referenced the EGR tube which appears to connect to bottom of rear horn as shown, Click here
that is correct, the earlier egr came off the main manifold piece below where the #5 exhaust port is located
pic above is the later 79+ manifold
Can anyone @mattressking find the parts diagram for my type of exhaust manifold? The style with no bolt holes for the heat shield?
being yours is from out of the country.
did it ever have a shield?
I don't recall seeing them on central American rigs, but never really looked
It never had a heat shield. I am curious what version this 3 piece manifold is. I did find a 1981 Colombian 40
fj40L-KC from Fj Company that has the same manifold I.e no heat shield holes.
If you dig around like you found, the Fj40L-K (KC) or similar General Countries '75-'80 trucks don't supply the heat shield, only difference is the part number for the manifold and which manifold unions it would use, otherwise the same.
