74 FJ40 - high beams stuck!
Marietta, GA
Looks like my high beam switch is broken, but I don't want to spend the money for a new one. Is there a way to turn the high beam off without buying a new switch?
Come on - it is worth the money to fix it correctly.
You can get a new OEM for $100. Or a used one from the classifieds here. But first you might just wanna pull the steering wheel, unscrew the switch housing, flip it over and and spray it with a little Deoxit if nothing looks worn in two.
Toyota Part No.: 84310-21010
Compared to modern headlights nobody should notice your high beams are on.
It can be fixed. If I can, anyone can.:hillbilly:Just tear into it, clean all the dry grease out, scuff contacts, re-lube with silicone dielectric. Never hurts to snap a few photo’s of how it’s assembled. I don’t think you’ll need to remove the turn stalk like I did.
