73 FJ40 - Random Complete Power Loss
Long Island
Since last fall my 40 has been reliable and trouble free - until last weekend. While cruising about 40-mph it suddenly shut down. No sputtering at all, just died. I coasted to the side of the road turned the ignition off, then went to re-start and it fired right back up. I ran it a couple more miles incident free. Motor is stock, but i'm running petronix ignition in stock vac retard distributor. I checked all the obvious wire connection to and from the coil and battery, and all seemed good. Any ideas? Thanks!
When I had the same problem it was a worn out ignition switch. I got a new one from Toyota. Mine is a Feb 1974.
Intermittent electrical failures can be difficult to track down. There are several approaches you can take but I think the first thing I would do is, with it running, wiggle and jiggle the key to see if you can get it to die again. Stop, restart, and repeat several times.
Gremlins suck! I had a similar problem and it bumfuzzled me for a year or so. Finally found out it was the little "magic" box on my Crane elec. ignition system. Went back to points and haven't had a problem since. Also had a friend with similar problem that turned out to be an intermittent problem with the fuseable link. Good luck!
PM me if interested in going with a refurbished vacuum advance distributor. If not, you can at least disconnect the vacuum line to the retard nipple on the distributor.
I had a '75 Camaro that had the same problem. Turned out to be a bad module in the distributor. Replaced it and all was right with the world again.
