'71 fj55 lc
Seals, gaskets and 4 to 3 gear and bearing for the TC.
4runner brake boost and master
I found a 92 4runner booster and master.Read that it bolted right up with the only mod. being,add 1/2" spacer at firewall and booster to compensate for a longer pedal adjust bolt.You could also cut the bolt a 1/2" but for the 55's you need the 1/2" spacer to clear the lip on the firewall.The booster is a slightly larger in diameter than stock.Well it fit right in,snug to the slave cylinder.Existing brake lines went right on after I put a riser on the T at the fender.And best of all,it works killer.Lockin up the new 33's
If you don't mind me asking-What did you use for the 1/2" spacer?? Sleeves on each bolt or a little more?
That's the set up I'm going with except I have 9mm fittings ('69 rig) and will be looking to adapt as I feel the brake lines are in good shape.
Great thread!!
Peter
Like the triple tone with the black on the bottom.
Very nice.
[Although the bench was rad. I could not take the ride any longer. Some buckets:)
ATTACH=full]931853[/ATTACH]
thanks guys...I believe they are out of a mazda something? made a frame,welded the seats to it and then mounted the frame to the original bench mounts. My center consol is a converted metal tool box also CB mount:)
Cleaned and caulked the gutters... Then back to original matching gray roof:)ATTACH=full]934641[/ATTACH]
